Previous in Forum: CuOF vs CuHCP   Next in Forum: Why would manufactured dill pickles smell like chlorine?
Generation of oxide atoms in gas state
08/17/2022 4:53 PM
I need to generation of oxide (O-2)atoms in gas state.
solid oxide fuel cell cathode doing this reaction of transforming diatomic oxygen to oxide.
can I use this type of material for this purpose
Re: generation of oxide atoms in gas state
08/17/2022 5:10 PM
08/17/2022 5:41 PM
many thanks
Re: Generation of oxide atoms in gas state
08/18/2022 10:01 AM
A spacecraft re-entering the atmosphere will generate <...transforming diatomic oxygen to oxide [ionised oxygen]....> , in which state it and any other ionised species present are usually described as "plasma". In this state, it doesn't hang around long, as it will react chemically, readily, with practically anything else present.
Good Answers: 11
08/19/2022 1:58 AM
If you're looking for some means of preparing or modifying a surface with ionized oxygen, an oxygen plasma system may be what you want. Typically, low-pressure oxygen is ionized with an RF generator. The oxygen may be produced by chemical means in the lab, or may be sourced from a commercially available oxygen bottle.
https://plasmaetch.com/oxygen-plasma-treatment.php
Anonymous Poster (1); MNIce (1); mohamed khalaf (1); PWSlack (1); SolarEagle (1)
