Previous in Forum: Charging stations   Next in Forum: How to hook up a comparator
16 comments
Good Answers: 32
Current Amplifier 20fA to 20uA range
10/26/2022 3:29 PM
I am keen in development of 20fA to 20uA range amplifier to digitise low level current from a pressurized ion chamber caused by the nuclear ionizing radiations.
Logarithmic current amplifier of 9 decades range will be ideal.
Anyone having experience with such design can share experience. All experts are most welcome.
Shyam Sunder Tiwari
Re: Current Amplifier 20fA to 20uA range
10/26/2022 6:20 PM
Maybe this will help.
Design femtoampere circuits with low leakage, part 1 - EDN
Electronic Design News (EDN) is a good source.
Good Answers: 32
01/29/2023 3:55 AM
Thanks for the link.
10/26/2022 9:22 PM
Radiation interactions are more like pulse events than any linear signal. So why not use gas amplification and pulse counters? Detecting a single ionizing event is quite simple in the Geiger-Muller region.
Good Answers: 32
01/29/2023 4:00 AM
Ion Chambers represent true exposure and are primary standard devices with larger dynamic range for 6 decades. Results are better with ion chamber. Radiation therapy uses Thimble Ion Chambers.
GM will turn out of ions quickly due to 10E+4 amplification. These are good for contamination monitoring.
10/26/2022 10:03 PM
This seems like an ordinary Geiger counter would work just replace the power source with a nuclear battery...or did I miss something?
10/26/2022 10:49 PM
10/27/2022 12:15 AM
Good Answers: 32
01/29/2023 4:06 AM
Yes, I agree, these parts LMC6001 are good that were made by National Semiconductor long ago for 10fA leakage.
AD549 of ADI and OPA128 of Burr Brown were 100fA leakage at best.
Few new parts are of similar level at 100fA leakage current. Reaching 2fA leakage is huge problem.
Good Answers: 32
01/29/2023 4:15 AM
Yes, these instruments are excellent for Radiation Therapy Ion Chamber dose profile calibration but are very expensive instruments few thousands of dollars range. I usually find them in cancer hospitals.
I am looking for $100 range solution that can be used by university students.
Good Answers: 116
02/05/2023 11:07 AM
A little late for a suggestion. Leakage current is very temperature dependant. Minus 5 Celsius may reduce leakage versus data sheet 25'C to 1/10. +1 'C to avoid ice formation?
  1. Use a peltier cooler? About 20 dollars.
  2. Run the whole head amplifier in the laboratory freezer?
  3. Scavenge the cooler works from a "scrap" freezer - for many the fault may not be in the cooler.
Good Answers: 116
02/05/2023 11:18 AM
When leakage is reduced significantly, feeding in an opposing offset current?
Good Answers: 116
02/05/2023 12:08 PM
Peltier device Tec1-12706 about 5$. 40 x 40 mm - enough for head amplifier? Cooling whole shebang should reduce surface insulation leakage as well as semiconductor leakage. Consider head parts connected in air on the "quick/ugly" wiring method to minimise solid insulation.
Good Answers: 32
01/29/2023 4:02 AM
Yes. See reply to similar #2 is #9 from me.
10/26/2022 11:26 PM
The equipment in beta gauging systems for on line inspection of metals and paper should be the design you are looking for. Some of the lower strength radioactive sources are krypton gas, directed into ion chambers. Not sure just how the intensity compares to your application, but the operating conditions are severe, think hot rolled aluminum plate or 70 mph wet & dirty paper machine web.
11/04/2022 10:43 AM
Pointer: the circuitry in chlorine instruments used in the clean water industry convert typically 100nA to a 4-20mA signal representing typically 0-2ppm free chorine.
Worthy of study, perhaps?
Good Answers: 32
01/29/2023 4:09 AM
100nA is large current and easier to detect.
20fA level detection requires 2fA bias current circuits.
Register to Reply 16 comments
67model (3); PWSlack (1); redfred (1); Rixter (1); rwilliams (1); Shyam (6); SolarEagle (3)
