Previous in Forum: Current Amplifier 20fA to 20uA range   Next in Forum: What is needed for a fiber/ethernet system
13 comments
How to hook up a comparator
01/31/2023 12:34 AM
This is not a “homework question.”
I want to use two identical thermistors. One placed inside a thermal collector, and one placed inside my shop.
When the voltages of the thermistors indicate that the temperature inside the collector are higher than inside my shop I want to put a forward bias on the base of a block of transistors controlling a small fan inside one of the two connecting conduits. What do I use for a comparator and how do I hook it up?
Re: How to hook up a comparator
01/31/2023 1:35 AM
01/31/2023 1:52 AM
You would also want to know the heat gain in btu's for your collector and the heat load of your workshop, this would determine the differential and cfm airflow to give a good cycling time...and also a max temp control for the workshop to shut the system off...
01/31/2023 2:27 AM
This guy has a series on differential controllers... this is #2
https://www.youtube.com/watch?v=LVU0RDclKp0&ab_channel=JohnCanivan
01/31/2023 3:04 AM
Thank you once again Solar Eagle.
01/31/2023 8:21 AM
Great link Solar
Gavilan, you need to look at the specs. of the thermistors to work out the value of the feed back resistor (shown as 100K).
Also watch out: you can choose to set the voltage at the negative input by using two resistors, or, leave the pot in place. But if you leave the setup as it is shown your fan will never turn off. When the two "rooms" reach the same temperature the biasing resistor will ensure that the fan stays on, and, there is no way that the room will get warmer than the collector.
You need to choose the voltage at the negative input and the feedback resistor so that the fan turns on when the collector is several degrees hotter than the room, and turns off when the room is a couple of degrees cooler than the collector.
A spread sheet would be a good way to choose the components.
02/03/2023 12:53 PM
I ‘ve considered a similar setup for my own shop/garage.
I am considering the use two thermostats - I have some takeoff bimetal-with-mercury-blob type thermostats available, so there is no expense for those.
Inside is conventional close circuit when calling for heat. Outside is close circuit when calling for cold. Wire outputs in series to ‘vote’. SPST to turn off in warm weather.
Not certain the exterior thermostat can be mounted (sort of) upside down to accomplish this. If not satisfactory, I can run a relay to reverse the condition/output of the gravity switch.
This is prolly not gonna happen for me. Approx 600 sq ft room with 11 foot ceiling, doubt I can harvest anywhere near enough heat to really matter with this scheme
02/03/2023 2:10 PM
Thank you for this interesting read. As far as harvesting "enough" heat? When it comes to heat, a joule is a joule. For every one you harvest from a collector is one you don't have to input using alternative means?
02/03/2023 4:00 PM
Absolutely, a joule is a joule. If the space were heated, this would be (for me) a bit of energy savings.
This is, however, an unheated space, and raising the ambient temp from 34 F to 36 F is not considered enough to perform putter type woodshop or model train projects in the winter.
I am limited in max size of the collector, about 18 inches by maybe 10 ft. In addition, the idea of a big black box with pipes in it bolted to the garage (the front of the house) has not yet been presented to the minority stockholder (49-1/2%), and a fair amount of resistance to this practical and inexpensive scheme is anticipated.
02/04/2023 5:59 AM
"In addition, the idea of a big black box with pipes in it bolted to the garage"
I remember Del The Cat did a workbench creation on a solar water heater:-
https://cr4.globalspec.com/blogentry/4969/DIY-Solar-Hot-Water-Panels
02/04/2023 3:49 PM
I think your method is the simplest:K.I.S.S.!
02/04/2023 4:36 PM
What makes my idea better for me is the fact I have the take off thermostats from an install I did. These seem to be about $30 bucks USD each from varied sources.
Our OP Gavilan may not have any of these and is trying to keep the expense down. Can’t blame him, many of my day-to-day consumable items (coffee beans, socks, motor oil... ) are 50% to 100% increase in price over the past two years.
[edited - removed some whining about the higher cost of getting by. We all know what is going on]
02/04/2023 8:09 PM
I bought some groceries the other day,and the man at checkout had a large wart on his chin.
I tried not to stare,and said nothing.
He said "Thanks for not mentioning the wart on my chin."
"Wart?Heck,everything else around here is so high,I thought it was your navel."
02/07/2023 4:47 AM
Register to Reply 13 comments
Doorman (3); Gavilan (2); HiTekRedNek (2); PWSlack (1); Randall (2); SolarEagle (3)
