Previous in Forum: Paper   Next in Forum: How Do I Encapsulate/ Granulise Oil
Wetting of galinstan
12/11/2007 4:15 AM
Gallium Indium Tin eutectic (other name: galinstan)wets glass. How to avoid this wetting, so that the glass remains clear?
Re: Wetting of galinstan
12/11/2007 5:34 AM
Substitute a different material with a different surface tension. Mercury, for instance?
12/11/2007 2:51 PM
No, definitely no !!! : Using mercury instead of galinstan is NOT the good idea: on the contrary, as mercury is toxic (and particularly its organic compounds: cf Minemata, Japan..), the challenge is to replace mercury by galinstan...
Canada - Member - New Member
Good Answers: 11
12/11/2007 11:40 PM
A vapour deposited coating on the glass may help.
I am guessing you are making thermometers or manometers and don't want to use plastic tubes.
Parylene coatings are quite tin and will go inside small cavities.
12/12/2007 3:02 AM
You are right !!! I am interested in manometers. So, I have to investigate in coatings. Thanks.
03/17/2008 4:13 PM
Just coat the glass tube with Galium oxide. (this is used in thermometers)
Good Answers: 50
12/12/2007 1:54 AM
Use a little very low viscosity oil... Like ethyl alcohol.
12/12/2007 3:06 AM
Ethyl alcohol is not be the solution:I need a liquid with density over 2, and vapor pressure very very low (under 10 mbar...)
Anonymous Poster (1); gigaconcept.com (1); jacquesmf1 (3); PWSlack (1); vermin (1)
