Previous in Forum: RCCB Trips While ATS Source Changes from Normal to Generator   Next in Forum: Line to Neutral Fault on TN-S System
Earth Rods and Inspection Pits
01/15/2024 2:47 AM
Hello
I would like to know if there is a standard that specifies the number of inspection pits for earth rods or always the number of inspection pits should equal the number of earth rods
Thanks in advance
Pathfinder Tags: Earth Rods inspection pits
Re: Earth Rods and Inspection Pits
01/15/2024 6:16 AM
The Earth pit is a structure built over the grounding rod for inspection and testing...You need one earth pit for each grounding rod...you can have an interconnected earthing system where several grounds and neutrals are connected, each needs an inspection pit...
Details on this link...
https://axis-india.com/es/earth-pit-technical-aspects-construction/
01/15/2024 7:14 AM
Each jurisdiction will have its applicable standard: British Standard 7671, Indian Standard 3043, etc.
Here are some documents that illustrate.
01/17/2024 11:03 AM
The <...number of inspection pits...> cannot exceed <...the number of earth rods...>.
Register to Reply 3 comments
