Previous in Forum: HIGH TENSILE STEEL???   Next in Forum: Taking Advantage of Atmospheric Moisture
Differential Pressure Switches
12/12/2007 5:47 AM
How can I select the water differential pressure transmitters?
Re: SELECT OF DIFFERENTIAL PRESSURE SWITCH
12/12/2007 6:59 AM
Start by specifying the range that is wanted and the output format.
Good Answers: 54
Re: Differential Pressure Switches
12/12/2007 10:59 PM
  1. What range is needed?
  2. What is the medium being measured? clean water? dirty water?
  3. What is the temperature of the medium?
  4. What is the environment around the transmitter? clean? salty (as in by the sea shore)? dusty? potentially explosive?
  5. How far will the transmitter be from the controller, indicator, PLC, etc.?
  6. What features do you need? local display? if local, digital or analog? Fieldbus communication or 4 to 20mA signal transmission?
  7. What's your price ceiling, if any?
There could be more questions that you will need to answer before you make a selection. In the end, you have to make sure that your selection really fits your requirements.
