Previous in Forum: IEC 62271-200: HV/MV Switchgear - LSC2B   Next in Forum: Plastic Cover for Low Voltage Breaker
PLCs in Electrical Engineering: Reliability and Optimization in Industrial Control Systems
04/03/2026 10:59 PM
In the field of electrical engineering, control systems play a central role in ensuring stable, safe, and efficient operations. Among these, Programmable Logic Controllers (PLCs) have become essential components, enabling precise control of electrical equipment and optimization of overall system performance.
From an electrical engineering perspective, an important question arises:
How do PLCs contribute to improving system stability, reducing energy losses, and enhancing operational efficiency?
Modern PLCs, particularly those developed by manufacturers such as Mitsubishi, are designed with fast signal processing capabilities, high durability, and reliable performance in harsh industrial environments. These characteristics help maintain system continuity, minimize failures, and reduce risks associated with overloads or control errors.
In industrial electrical systems, PLCs go beyond basic logic control by integrating advanced functionalities such as:
  • Real-time monitoring of equipment status
  • Sequential control of electrical processes
  • Intelligent control strategies for energy optimization
  • Integration with SCADA and HMI systems
As a result, PLCs significantly improve both the efficiency and safety of electrical systems in manufacturing plants and production lines.
However, selecting an appropriate PLC is not solely a technical decision. It also depends on the specific requirements of the electrical system. Key considerations include I/O scalability, power stability, noise immunity, and communication capabilities.
This leads to several discussion points for engineers and professionals:
  • Can PLCs fully replace traditional relay-based control systems in industrial electrical applications?
  • What are the most critical factors affecting PLC stability in high electrical noise environments?
  • How can PLC configurations be optimized to reduce energy consumption in industrial systems?
Sharing practical experiences and insights can contribute to a deeper understanding of the role of PLCs in modern electrical engineering systems.
Pathfinder Tags: PLC
Re: PLCs in Electrical Engineering: Reliability and Optimization in Industrial Control Systems
09/15/2026 3:37 AM
Great points. Having dealt with both legacy relay panels and modern PLCs (like Mitsubishi’s iQ-R and Siemens S7) on the plant floor, here is my take on your questions:
  • Can PLCs 100% replace hard-wired relays? Almost, but not quite. While PLCs handle 95%+ of process logic, physical safety relays and hard-wired E-stop circuits aren't going anywhere. You still need that physically guaranteed air-gap power drop for emergency stops, CPU faults, or basic isolation circuits where a $20 relay is just simpler and bulletproof.
  • Beating noise in high-EMI environments: VFDs and large inductive loads are the usual suspects. In practice, keeping the PLC alive comes down to strict cable separation (crossing power and signal lines at 90°), proper 360° shield grounding on analog cables to avoid ground loops, and using isolated DC power supplies/filters directly in front of the PLC rack.
  • Optimizing for energy savings: The real wins come from code logic. Programming smart PID control loops for VFDs instead of running pumps/fans at full throttle saves massive kWh (thanks to affinity laws). Auto-sleep states for conveyors/HPUs during idle time and integrating power meters via Modbus to automatically shed non-critical loads during peak tariff spikes also make a huge difference.
Curious how others here are managing cable routing and grounding in tight control cabinets full of high-frequency drives!
09/15/2026 5:34 AM
<...How do PLCs contribute to improving system stability, reducing energy losses, and enhancing operational efficiency?...>
Without appropriate programming, they cannot.
<...Can PLCs fully replace traditional relay-based control systems in industrial electrical applications?...>
Largely, although it is still advisable, and in some jurisdictions mandatory, to use hard-wired controls where the assurance of personal safety is paramount; there has to be a way of preventing PLCs from causing injury or death.
<...What are the most critical factors affecting PLC stability in high electrical noise environments?...>
The quality of the signal wiring and the rigo(u)r of signal validity checking within the program are two of them.
<...How can PLC configurations be optimized to reduce energy consumption in industrial systems?...>
PLCs don't do this. The process design does. It begins with the most important documents, the Process Design and the Control Philosophy (which defines what, when, where), from which the next document, the Functional Design Specification [FDS] (which defines how) is created. Until FDS is at an "approved for construction" issue, there is really very little point in starting.
Register to Reply 2 comments
