Previous in Forum: What Usually Makes a PUE Below 1.2 Difficult to Achieve?   Next in Forum: How Much Structural Headroom Should Colocation Data Centers Allow for AI?
Piping Max Design Temperature Based on Ambient Conditions
07/15/2026 11:23 AM
A large proportion of the piping systems I have viewed recently have ambient temperature as the max thermal condition.
Considering the recent severe climate changes we are experiencing in the UK, it seems 40C is not to far off as an air temperature and looking at Europe's experiences, higher 40's are on the way.
What should now be considered as an acceptable max design temperature to satisfy codes ASME B31.3, BS EN 13480, etc & HSE, bearing in mind anticipated solar radiation heat gain.
Pathfinder Tags: max design temperatures
Re: Piping Max Design Temperature Based on Ambient Conditions
08/04/2026 11:19 PM
Solar heat gain can push the actual pipe wall temperature well above the measured ambient air temperature.
For outdoor piping under direct sun, many oil‑field piping projects add 10‑15 °C margin above the maximum historical ambient temperature to cover solar radiation effect, when complying with ASME B31.3.
It is not only for rigid steel piping, we also pay close attention to this temperature margin for high‑pressure flexible hoses and manifold assemblies working under open‑air hot climate.
It would be risky to only use air temperature without solar correction.
Lonsuctech LLC High pressure hoses, plug valves & piping components https://lonsuc.com
08/05/2026 3:34 AM
Thank you for your comment. +10 to15C seems to be a generally used number for solar radiation effect. When applied to plastic piping systems this can have a significant effect although all systems need consideration to determine whether any issues need attention.
09/10/2026 3:46 PM
A good piping equipment supplier will already have a de-rating protocol for each type of pipe on offer. Bear in mind also that the temperature of the wetting agent inside the pipe will also have an effect, as will its insulation and its support method.
This is probably better dealt with by telephone and not CR4.
Register to Reply 3 comments
bee song (1); PWSlack (1); Screedie (1)
