Previous in Forum: A Simple Tolerance Change That Can Significantly Reduce Manufacturing Cost   Next in Forum: U Tube Bundle Inspection
8 comments
7 Line Facial Tissue Folding Machine
09/03/2026 2:27 PM
I have a problem with conveyor 2.
When the knife is switched on, the paper starts to pull out regardless of the speed i use, and after few minutes the paper falls out completely from the front.
I have tried to increase the % of conveyor 2, I have tried to increase the tension of conveyor 2, I have checked the air gauge pressure which is at 4.0bar
I dont know where else to look.
Please if anyone can help, it will be great...
Thank you
Re: 7 Line Facial Tissue Folding Machine
09/03/2026 4:09 PM
Further to my post above please receive videis abd photos
09/04/2026 6:55 AM
So many missing details! I, for one, have no idea what kind of machinery you are describing or the process you are attempting to carry out except for the fact that there may or may not be 2 conveyor units involved.
Better questions get better answers. More details - pictures, diagrams, schematics. Something. Anything...
09/04/2026 3:08 PM
The video you supplied looks very helpful. This might be a C fold machine?
I have never worked on one of these, it appears that the roller you have is either folding or cutting. Could it be the tension is not the same on the web from left to right?
Does this happen on any specific lane of the parent roll, traced back to the machine?
Humidity, static electricity can make webs do unplanned or unanticipated behavior when entering a converting machine.
More data on your machine might help those of us who have not trouble shot a c fold machine..
09/05/2026 6:38 AM
Is this an existing machine, in place and performed correctly for some period of time?
Is this an existing machine, in place and performed correctly, that has recently had worn components replaced, or maybe been upgraded?
Is this an existing machine that has served faithfully for many years, and is in need of overdue maintenance and service?
Is this a new machine in an existing line, it has never worked quite right?
Perhaps it would be better to cease fiddling with settings and determine the cause of the trouble?
As already stated, more and more complete information should get you better assistance.
09/10/2026 5:57 AM
How did the phone call with the equipment manufacturer go?
Good Answers: 54
09/23/2026 2:08 AM
It might not be a case of speed. Is your blade still sharp? Is it properly aligned/mounted? Are the conveyors synchronized? When you switch on the blade, are the conveyors becoming unsynchronized?
You first need to know how the machine works so that if it deviates, you will know why.
regards,
Vulcan
Good Answers: 54
10/09/2026 3:31 AM
Might it be a case of humidity? Tissue paper is hygroscopic I believe and if there is too much humidity in the air, it may start to stick to surfaces. Maybe your facility needs to be air conditioned to lower the humidity. Alternatively, you can place a small dehumidifier to condition the air around the machine so that you won't have to do the whole building.
regards,
Vulcan
09/29/2026 10:04 AM
I agree with the comments. We need more information in order to provide a decent answer.
But assuming what I can, the fact that the paper starts pulling as soon as the knife comes on makes me think something changes in the timing or drive of conveyor 2 when the knife engages.
I’d check the conveyor 2 motor/drive and encoder, and make sure the belt isn’t slipping. Also watch the paper tension when the knife comes on. If the tension suddenly changes, that’s probably where the problem is.
The 4 bar air pressure and higher conveyor settings don’t seem to be fixing the actual problem.
MalcAndCheese
Devmanco (1); Doorman (1); dougefresh (1); MalcAndCheese (1); PWSlack (1); rwilliams (1); Vulcan (2)
