Previous in Forum: Switching Professions   Next in Forum: Jerking in Lines
11 comments
Optics and Reverse Images
12/13/2007 3:49 AM
What are the surfaces/mirrors called where we can see the reverse image when we look in to that? Why it is so? What are the properties of that?
United States - Member - New Member Engineering Fields - Optical Engineering - New Member Popular Science - Cosmology - Astrometrist Engineering Fields - Engineering Physics - New Member
Re: Optics
12/13/2007 6:07 AM
This type of mirror is a concave mirror. If your face is far from the mirror, your image is inverted. If your face is close to the mirror, your face is right side up, but larger. To understand this concept one needs to study geometrical optics.
I have constructed a simple ray diagram. If the mirror is a sphere drawn by a compass, then the center of curvature is the location of the fixed point of the cumpass when the mirror's surface is drawn. The focus is the location of where light rays from infinity would all cross. It is half way between the mirror and the center of curvature. The image is the location where the CCD chip of film would be location if this mirror were in a camera.
Consider the tip of the arrow. I have drawn two rays. One moves straight to the mirror and is bent through the focus. The second hits the mirror at its center and reflects at an equal angle to the axis or center line of the drawing. The location of the intersection of these two rays is the image. If the image is below the center line, the image is inverted. If the image is above the line, the image is erect or the same as looking into a normal flat mirror.
The concept is more complicated if you are looking at the image with your eye because your eye is a lens which images the light on your retina or if you were the object in the diagram, your eye re-images the image which is close to the mirror. However, lets discuss what happens. Iif you are far from the mirror, your image is upside down and small (as in the ray diagram). If you walk towards the mirror, your image becomes larger until you reach the center of curvature. Then the image is infinitely big and dissapears to your eye. Continue to move closer to the mirror. Your image is now erect or right side up but larger. Such concave mirrors are sold for people to use to see their faces enlarged to help put make up on, etc.
Further reading can be found at Wikikpedia on optics , expecially the geometrical optics references as lenses and mirrors.
George
Re: Optics
12/18/2007 3:24 AM
Thanks for the information. It was really helpful.
Good Answers: 97
Re: Optics
12/13/2007 6:08 AM
If you look into the long flat surface of a prism you will see the inverted/correct image image.
The 2 short sides act like mirrors and are both at 45° to the viewer.
2 mirrors placed at 90° to each other and at 45° to the viewer will invert the image. Light coming in from the front on the left hand side is reflected at 90° to the other mirror where it is again reflected at 90° back to the viewer. The same happens with light entering on the right hand side. (reflected on the left hand side).
This produces good inverting of the image.
A parabolic shaped mirror will also invert the image but it will be scaled and give the impression of a 3D image.
Another possibility is that a camera and a flat screen combination may appear to be
a inverted mirror image.
Re: Optics and Reverse Images
12/14/2007 3:52 PM
Being an amateur astronomer I have the following links for you to read and study.
http://www.freesciencefairproject.com/physics/Optical_Instruments/index.html
This explaines all the principles of lenses and lirrors and how they are used and why the images are what they are.
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/teles.html
This one explaines the same but now with comparison to how the eye works.
Hope this explains and tells you what you were looking for.
Any more don't hesitate to return.
Regards,
Case491
12/14/2007 4:22 PM
Uhh, I did mean MIRRORS
12/14/2007 10:19 PM
I believe so.
But did you mean to shout about it.
Geez pour another pint, that explaines it.
12/15/2007 5:19 AM
Just the frustration of the inability to operate my keyboard pouring out once and a while, sorry.
Maybe I should have changed it to menses and lirrors.
I am trying to cut back on the pints, don't get me wrong, I do like them and still have some but not to the point you wake up with a heavy feeling in the head and the inability to operate keyboa.......shit!
p.s. the spell checker does not pick up menses, what the heck is that word? I'll have to go and find out now.
12/15/2007 9:54 AM
menses
Now that is really "learning from our mistakes." And I didn't even break anything.
cr3
12/15/2007 10:14 AM
"YUK"
You mean you learned from my mistake, can I have at least some credit please.
Thank you for looking it up, I had forgotten about it
12/14/2007 4:14 PM
go ask Alice
02/18/2009 7:16 PM
dunno
Register to Reply 11 comments
Anonymous Poster (1); case491 (4); GWJ (1); Hendrik (1); manikumarp (1); SGQ (1); TexasCharley (2)
You might be interested in: Hot Mirrors and Cold Mirrors, Optical Mirrors
