Previous in Forum: Delta/Star Connection   Next in Forum: What Happens to Light Energy?
17 comments
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
What Kind of Transistor?
12/13/2007 10:30 AM
Hey guys, I have been trying to identify this transistor that I found in a schematic. I have searched the web, but haven't found anything. Is this just a regular NPN transistor?
David A Goodman
Re: What Kind of Transistor?
12/13/2007 11:16 AM
Looks like some kind of MOSFET.
Does this help?
http://en.wikipedia.org/wiki/MOSFET
Vote for something useful this time, vote to repeal the second law of thermodynamics!
12/13/2007 1:43 PM
I was thinking it might be a MOSFET and even looked at that page on wiki earlier. I can't find any kind of reference to that symbol. Very strange. I was hoping to identify it so that I might understand the operation of the circuit. The circuit is for a windmill control circuit and the transistor is used in some sort of bridge rectifier circuit.
David A Goodman
Good Answers: 18
12/13/2007 2:17 PM
It's probably an IGBT (insulated gate bipolar transistor). Works like an FET driving a bipolar transistor, and they're a lot more rugged than MOSFET's.
12/14/2007 7:52 AM
Yes, it looks like an IGBT
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
12/13/2007 2:53 PM
The schematic should ID the transistor which is included/referenced in some type of BOM or parts list. If nothing , then identify its function in the ckt and the purpose of the contraption it is soldered to.
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
12/14/2007 1:26 AM
It can be an "N" channel MOSFET or a FET-Darlington (NPN bipolar transistor driven by a FET)
Aged man is not old man...
12/14/2007 1:41 AM
Looks like an IBGT but someone forgot to draw that little diagnal line in the middle.
12/14/2007 4:52 AM
I agree with that: if I had to design a symbol for an IGBT that's what I'd have done: here's a document which shows the symbol HGLDR is referring to:
http://www.onsemi.com/pub/Collateral/AN1541-D.PDF
12/14/2007 10:36 AM
Randall, Bill, PLM NY
I think, too, that it is the IGBT. The symbol is for the right hand side a BJT and for the base drive, the MOSFET.
Actually, from the link you gave:
When compared to BJTs, IGBTs have similar ratings in
terms of voltage and current. However, the presence of an
isolated gate in an IGBT makes it simpler to drive than a BJT.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 12
12/16/2007 4:37 PM
Much Thanks Randall!!
That is a really handy app note which I saved for future reference.
Bill
12/14/2007 5:27 AM
Most of the schematic circuit diagram show IGBT like the one you have presented.
But the actual standard symbol has an inclined line between collector and emitter.
12/14/2007 6:38 PM
why not understand how the base is being driven and work with that to find if it's a transistor device or not. that or measure the resistance between base and or the other two points.
Out Of The Inner Circle
12/14/2007 7:21 PM
BJT are driven with the base current. FET, IGBT are driven by voltage (if we do not consider the charging current of the base-emitter junction (I have used the pin names from BJT). Look for data sheet for the transistor you have in hand, and there you will find what you need to make it work.
12/16/2007 4:55 PM
12/17/2007 8:02 AM
Thanks for all of the input. I sure do appreciate it. It appears that the device is an IGBT. The application note was extremely helpful. The device is used on the control circuit for a wind turbine and is indeed a power application. It looks from the schematic like it "senses" the output voltage from each phase and manipulates the output of the rectifier accordingly. now that I know what it is, I can figure out how the circuit works.
Thanks again,
DAG
David A Goodman
03/20/2008 10:42 AM
Yes, this is N-channel IGBT.
Mostly its using for voltage over 300 V, at lower voltage it has a good competitor – CoolMOS or Superjunction MOSFET.
01/08/2008 7:13 PM
It is an insulated base transistor. I've only seen this once in my life.
Register to Reply 17 comments
Anonymous Poster (1); Bill (1); DAG (2); Hap (1); hgldr (1); indel (2); lordravindran (1); PLM NY (1); powersemi (1); Qqberci (1); Randall (1); ronald (2); Sciesis2 (1); Zaphod2Headed (1)
