A friend of mine is in the salad preparation and processing business for a restaurant chain. He wants to know if his machinery, used to wash lettuce and cabbage, have to be Qualified/Validated or Certified?
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
Arecibo, Puerto Rico and that is all I can divulge for now.
Up here in the USA, all equipment that comes into contact with food would have to be certified by the National Sanitation Foundation (bears the seal "NSF"). In addition, the facility would have to be inspected and certified by a local health department or, in the case of the State of Pennsylvania, certified by the PA Department of Agriculture. At least one person certified in food safety would have to be in charge of the facility when operating.
You may have similar requirements, or you may be totally un-regulated. Maybe a call to a local government office will at least get you on the right track.
Sorry my response can't be more definitive.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
"Up here in the USA, all equipment that comes into contact with food would have to be certified by the National Sanitation Foundation (bears the seal "NSF"). "
Where did you get this?
I have been designing and fabricated dairy process equipment for 15 years. I have been following the codes that applied locally whether it be state WDA, CFA.or federal, FDA, As well as using USDA -3A as a basis. And then have the USDA - 3A inspector (or state/local inspector) do a onsite inspection at my shop before it leaves to the customer or the customer does at his facility.
Have I as well as my competition and my been doing it wrong? (some of the companies I compete with does 50,000,000.00/year)
Or is this a standard practice in your area, either way can I see a federal ruling stating this. Or is this just an organization that you can belong to.
phoenix911
Hi, I read your response and I thought I'd check your CRED's. Lo and Behold, somehow I knew. It was Deja Vu for me. I swear I thought I was looking at my profile. Funny; but when you're over the hump and and a Pseudo-Guru, nobody wants you around...! Good Luck in conslting; I'm doing my best to stay sane. My hurdle is flying; it scares me, I've lost alot of opportunities...
The problem I have is not trying something, and then having to go through life asking yourself, what if or I should have.
I did it or tried it. (for better or worse)
it is interesting what road one takes in life. The people you meet and the things you experience.
As far as your original post. I pass along what I have seen. (sometimes very unbelievable)
Since he is a suppler, vegetables have a lower sanitary requirement, basically it has to be clean and be cleaned regularly, it can not have a bacteria build up, or leave foreign objects in the product.
I'm am sure his facility gets inspected, (if not have to look in that). since he does have a business, I am sure he has insurance, This has really hit the spot light do to the recalls due to bacteria contamination this past fall. This can happen and have to the cleanness facility.
Good luck,
phoenix911
I believe he's at the start-up stage. I did install all the centrifuges, (w/VFD) and alarms, the sanitary roll-up doors, the bag sealers and I also implemented a test method for bag seal integrity, (vac and food coloring), his budget does not allow for testing equipment for now.
The centrifuges are used to remove excess water from the cut lettuce after the wash process. Have no idea of how many wash processes are involved; only know of one. Do know that there are several stages...? When all is done and finished, I might be asked to get involved in some aspect of the process since he's a good friend. It's OK to ask more questions; I will learn more as we go along.
I also must question this statement. NSF has tried in the past to sell us their services. They are a 3rd party services/certification company, which I am sure are quite good. But regardless, to the best of my knowledge, they are not a regulatory body.
Our food processing / baking facilities go through multiple audits a year. Typically customers or ourselves hire these agencies (such as NSF /AIB / Cook & Thurber) to come through, beat us about the head and shoulders, and make us better for it.
We use over 60,000 lbs of pastuerized egg every week, locally in this one plant alone. Because the eggs are pre-pastuerized, we do not fall under USDA inspection guideline, but in fact remain under typical FDA GMP regulations per Title 21 CFR 110 (and a few dozen others, I'm sure). We are required at any given time to show holding temps, contaminant test results, sanitation procedures etc., but this equipment bears no certs beyond my local sanitation seals reflecting when and who cleaned it and which CIP method was used.
Unless Ronald's friend in Puerto Rico is starting up a new facility...the local regulatory requirements should have been clearly defined and met before the 1st slice and dice. The requirements may be completely different than the local stuff if he is, or is planning on, sending his product out of the Territory up to the States.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
As for as between a new facility and upgrading an existing, one of the most abused loop holes, is the grandfather loophole.
After looking at their web site, that is all there is, It actual is just a business. similar to ASME.
But on a tangent, I understand that if you build pressure vessels like ASME, you do not have to be ASME certified, but you can not use any words like ASME in your advertising. I worked for a company, that sent their welders for weld test like you would for ASME. and then they put wording on the tanks stamp, that they were ASME certified tested. When I started working for this company. These nephews of the company (as well as thier uncle) tryed to blow this smoke up my @%%. saying its OK. I did not fully understand ASME and thier requirements, but this sounding like crap.
I had them pull the tags, and when my job was in jeopardy, I told them if ASME found out, they would have to send people to each vessel they did this to, (including someone from ASME to verify) and remove any reference to ASME with a grinder, as well as false advertising.
This includes the ones that went to international, such as China , Europe and Australia. That put a damper on there greed, shut them arrogant boys up. Over 1,000 vessels and heat exchangers.
Since then, I set them up to carry the 'U' 'PP' and 'R' stamp. And washed my hands of that company.
