Previous in Forum: Teflon Coating For Car   Next in Forum: Water, Muffler & Car Engine Mystery
Not Enough Gas in the Car
12/14/2007 10:28 AM
I PUT FUEL INJECTION AND CARBUETOR CLEANER IN MY 1997 GRAND AM WITHOUT A FULL TANK OF GAS, NO IT WONT START...WHAT SHOULD I DO?
Good Answers: 918
Re: NOT ENOUGH GAS IN THE CAR
12/14/2007 10:31 AM
First, release your caps lock on your keyboard.
Next, I would start with purging what is in the tank and fill with conventional gas (at least a half a tank).
Finally, pull and replace the spark plugs (if needed), and try to restart the car.
12/14/2007 10:38 AM
thank you, should i replace my spark plug wires?
Good Answers: 918
12/14/2007 11:27 AM
If it is dry outside the wires probably will start the car, but you did not give us much in the way of facts about the car, its condition, age or history. So, it is not clear to me what is needed.
If the car ran before, ask yourself; what changed? How long has it been since it last ran? What was it running like before it stopped? When you tried to start it did it run at all or just crank without firing?
Generally, it can be one of two things that prevent a car from starting. One is spark. The other is fuel. You can also have a timing issue, like the timing belt breaking. Then the valves will not open and close at the right time or at all.
Checking for spark is easy. Just pull a spark plug cable off and attach a spark plug with the threaded end grounded to the engine. Have someone try to start the car and see if you can see a spark at the plug's end. If not, then you have an electrical issue most likely.
If the spark is there, test for fuel. Pull a plug and smell it. Is it soaking wet (if yes, the car is flooded)? Is it clean (if not, maybe the plugs are fouled)? If there is no fuel smell or wet plugs, then it could be a bad fuel pump. Fuel injected cars have a DME relay in the fuse box that can go bad.
Try reseating the relays. Look for bad fuses. Tap the relays with the back of a screw driver when you try to start it.
Or maybe you just should call AAA.
12/14/2007 7:16 PM
thank you....before this happen with my car, it had cranked up and ran pretty good until about two weeks ago...it started to spurtter when i gave it gas?
Good Answers: 97
12/14/2007 1:27 PM
I was driving into the country side this morning and heard the following story (with half an ear - I dont know where)
A man stopped at the petrol station and pump some petrol into the interior of the car paid the attendant and drove off.
The police were informed and the caught up wit him and booked him for the night.
His car did not stop because he had enough petrol in the car.
Good Answers: 54
12/15/2007 5:30 AM
Carburator cleaners do not support combustion, if I understand an article about them correctly.
When using them to clean the carburator, they recommend spraying outside the thing first. Then start the car and spray small amounts into the carburator air intake. The engine will start to sputter but if you use small amounts, it won't die on you.
I tried it myself and it does what the article said it would do. Didn't improve my engine's performance but I guess the carburator wasn't so dirty after all .
I don't understand what is the significance of having a full tank of gas when you use the cleaner. I didn't have a full tank either but my car never stopped when I was using the product.
It just occurred to me that you may be using something completely different. In that case, just ignore my rambling.
Register to Reply 6 comments
Anonymous Hero (2); Hendrik (1); tonyrome4u (2); Vulcan (1)
