Previous in Forum: Effect of Leading Power Factor in Transmission / Distribution Lines   Next in Forum: 6 types of 3 phase motor starters
13 comments
wind generator
12/15/2007 4:37 PM
looking for help in building 3-5 vertical Wind generators, about 500 units.
please e-mail with suggestions to: foridel@yahoo.com
Good Answers: 247
Re: wind generator
12/15/2007 6:04 PM
You'll need to clarify this: are you building 500 units or 3-5 units? What kilowatt size are the generators?
Re: wind generator
12/15/2007 11:14 PM
500 units.
we have many many requests from Europe coastal towns.
we also have a contracts from schools and so on
We sourced already PMA generators from China at really good prices
Good Answers: 230
Re: wind generator
12/15/2007 11:20 PM
Hello foridel,
If you are the original question asker, please advise the generator output/s.
Are they identical?
Do they have different maximum output ratings?
What are the actual ratings.
Location, so year-round wind speeds and/or winter ice loading of vanes can be allowed for.
That should enable a better answer next time..........
Re: wind generator
12/16/2007 4:59 AM
Make a start here by clicking on this link:-
Savonius Wind Turbine
Please do not forget that there are many safety requirements that need to be followed in any windmill project, I will list a few, the list will be far from complete......
1) Need to be able to stop the windmill for maintenance and repair, a brake alone is not good enough as if the brake suddenly fails, someone could get killed either by mechanical action or electrical action.
I liken it to putting a sailboat into wind, the sails are up, but a sudden shift of wind and the boat will be driven again. You must drop the sails to remove the chance that the boat will move. So you need to either "fold" your windmill, or drop something down over it to to remove any chance of it turning. The brake should only be used to bring it to an initial halt, nothing more. A good design will not need a brake anyway.....
2) Proper electrical installation with ELCB protection, installed and designed by a professional. Assuming mains voltages. If batteries, then a proper charge controller that will be a) adjustable b) never overcharge or gas the batteries. If batteries gas, there is a chance of an explosion, so fully ventilated with warning signs for cigarettes and naked lights etc.. Use leisure type batteries, not car batteries, the Leisure type are more forgiving in many ways, but more expensive too....
3) Design windmill to withstand at least 3 times the maximum possible expected wind speed for that area, some might say more to be fully safe, I would not argue with them.
4) Utilise bearings and other parts that are sealed against water and dirt, and are far larger than theoretically needed.....use metals that do not corrode easily. Do not skimp in any design areas. Remember, re-building 500 units due to a failure will cost you your business.....so test in an exposed area for at least a year before finalising your designs.....charge accordingly, but good ones will not be cheap or sell as a kit with all the responsibility on the head of the builder, not you.
I hope this helps.....
Good Answers: 117
Re: wind generator
12/16/2007 11:21 AM
I think I have said this before on this forum, but around here we figure a windmill's payback time (considering mast erection, maintenance, batteries, disposal fees for used batteries, and land cost) is around 30 to 40 years, and the windmills effective lifetime is less than 20.
The efforts to improve this include higher outputs (larger units), cheaper batteries, longer maintenance cycles, economies of scale, cheap or subsidised land, electrical inversion (so you can use transformers) and computerization. I understand some wind generation "farms" are actually making money in some parts of the world. Not if they are selling the power for ten cents per kilowatt hour...grin!
The cost of a power installation of any kind is not the initial generator sets, but rather the long term maintenance. You have to be looking at wiring which can withstand the weather for 40 years plus or else is easy to replace. You should be looking at non-polluting cheap edison cells instead of expensive lithium ion or heavily polluting lead acid batteries. Wind power towers in PEI (Canada) kept getting knocked down by the wind with subsequent cleanup and dredging costs. These "minor" details take up 90 per cent of your costing, so even if you got the generator sets for half price, you can maybe cut 5% off the bottom line.
I know...the "sexy" part of the problem is the generation. However the money will need to be spent on the infrastructure. The road to get your maintenance crew up to the top of that mountain! The disposal of lead acid batteries....the replacement of computers when they get hit by the surge from lightning hitting the highest point in the area. The burial of copper wire to prevent copper thieves from ripping them out. Get a handle on those expenses, and you can get the generator sets anywhere! Those inexpensive ones you have already sourced out might be ideal, but they are not where the money will be spent.
Just sayin.....
Re: wind generator
12/16/2007 2:10 PM
Lead acid batteries have, at least in Europe, an almost 100% recycle rate, far better than almost anything else in this world that you can mention.....other batteries, cars even houses or what ever.....
So I know they are not exactly energy efficient, but this ability to be almost completely (and at reasonable costs) recycled should not be either ignored or depreciated.......!
Its probably one of the reasons they are still around....
I cannot dispute your other figures, but if the payback on a windmill is as bad as you say, as you seem to know it, why are we building so many of them? Why is it that you know that and all the investment bankers do not?
I know its a good idea to develop knowledge in this area, but we have 1000s of them around in Germany now.....I can see about 20 just from my roof on the horizon alone!!! more each year.
Somehow I have the feeling that we are missing something.....but I do not know enough even to make a guess what it is......perhaps someone else can add some better infos....
Good Answers: 117
Re: wind generator
12/17/2007 1:21 PM
Remember all those variables? If you can get somebody to subsidize the roads leading up to the wind farms, AND the distribution network, If you can get somebody to gear up a factory and get some government money because you are producing "carbon credits", if you can get somebody to outlaw competing electrical energy plants (such as nuclear or coal), if you can convince a government to expropriate land and lease it to you for a dollar a year per acre to satisy political interests, then, the rest will be simply a matter of engineering a project. Its not a dirty little secret...its "how its done". And as a matter of risk management, anysubsidy or support which is done can be undone.
What do they know that I don't know? Well, "they" know how to get the politicians on board.
A cautionary tale...around here, even if you build it, then every level of government will suddenly crawl out from under their rocks to tax you on it. (I have the Corel Centre here in Ottawa in mind...grin! They built a freeway interchange and THEN changed their contract and charged the hockey team for it! Go figure!) And they can become very creative. A similar stunt with a wind farm would put it out of business.
Not that I didn't say it would be a bad thing...just that it would not be a profitable thing. But then, neither is a bridge across a river....and that is built for far fewer good reasons than a wind farm. But you ignore these variables at your peril.
APIX Pilot Plant Design Project - Member - New Member
Re: wind generator
12/16/2007 12:55 PM
You do not give your location and wind conditions. California and Texas have thousands of wind turbines in operation. Wind turbines from a few watts to megawatts are available. Type in google, "wind turbines", "wind power", etc.
chtank
Re: wind generator
12/17/2007 2:35 AM
Dear Friend
Please introduce yourself, which country you are located in, what is the application and what is the power rating you are looking for. Maybe then somebody would be able to come with an answer to your request.
Ashok Toshniwal, Bangalore, India
Re: wind generator
12/17/2007 2:25 PM
http://www2.northerntool.com/product/200320201.htm
There are quite a few of these on the coast (Washington's long beach peninsula) around my cabin (beach shack). They are all privately owned. For the price these seem quite reasonable.
Eastern Oregon has thousands of really large windmills for electricity. The three bladed towers have to be well over 100 ft tall. I saw just one blade go by on a semi truck. It was around 100 ft long. One of the local electric companies allows you to up your own bill to "use/support" this clean power.
Re: wind generator
12/18/2007 11:02 AM
Is there anyone from the power gen. industry out there reading this?
Someone that might know a thing or two about the grid an how credits for emissions, and forced outages affect this investment.
I have a strong feeling this is not a matter of making money.
Perhaps it has more to do with keeping their money.
Most energy in the world is produced from burning coal. Witht the laws changing, companies need to balance out their emissions to be under a certain level based on their output. Companies that cannot clean their emissions with FGD, SCR, and now CCS require that someone does. By producing without emissions, they are actually able to produce more coal power paying less in credits or fines.
This is what I have understood after researching the trends of major producers. They don't make money with solar cells or parabolic mirrors, but they keep more of their money.
Can anyone please confirm from the industry, or please help us all better understand.
Please include what your experience really is, because as I mentioned, mine is just based on reading about trends and legislation (sometimes it is all full of crud).
I know this goes a bit off topic from the initial question, but it seems that was abandoned for the moment anyhow.
Cheers,
Robert
Reply Score 1 for Off Topic
Good Answers: 117
Re: wind generator
12/19/2007 10:50 AM
My statements are based on chatting with my neighbour who, over a ten year period, did everything he could to "stay off the grid". He gives lectures locally on the topic. He feels that wind generation works just fine, but it is expensive when you figure in the associated costs. And forget about it being able to provide enough power to run a tractor to plow the fields, or for that matter, plow the snow in his driveway. His suggestions for improving matters tend towards economies of scale...factories producing many cheap, small, easily handled units instead of monsters which require massive debt load and special trailers and crane trucks. He also likes the units closer to home...figuring rightly that unless the generator is close to the consumer, more energy is wasted in transmission than gets delivered.
He also points out the holistic cost...that is, the cost in greenhouse gasses of producing the steel which goes into the crane truck and towers, the building of a paved road to carry the trucks (concrete is very carbon dirty), the massive amount of energy involved in refining copper, manganese, stainless steel, even paint! His phrase is "there is always an evil, the wisdom lies in selecting the lesser of the two evils".
You can simply google and find a company making a wind generator somewhere, the technology exists. What is now required is the will to use it instead of something worse.
Are these overlooked considerations adding to, or reducing the problem we are attempting to solve with wind generation?
And yes, this comment is totally off topic. sorry, I'll select the "off topic box now.
Re: wind generator
12/19/2007 11:18 AM
Thanks for the perspective.
Honestly, I am looking forward to a post from someone in the industry as well. You see an order of monster size units at 500 units per order is not your typical "friend off the grid".
In So. Fla. many Key West residents manage to stay off the grid and sell back metered credits most of the year. But you are talking about a completely different way of life than the folk in Miami, NY, London, etc.
Realistically, the effect of one dozen residents will not offset the trouble that a megatropolis produces. The companies making generators, turbines, etc. do not target their sales looking for one or two people here and there. The market is for industry (big or small).
I have just come back from New Orleans, where the PowerGen 2007 exhibit was. To be honest I believe not being able to store nuclear waste, and not getting permits to build any more coal plants around many states (reports keep showing), it is more beneficial to invest in renewables that allow them better flexibility with their emissions elsewhere, and they can sell those credits. BTW, we are not talking small change. These are hefty fines that can easily add up to be more than what is conserved with the guys off the grid.
I believe in green.
I wish our culture was different.
But I am not blind to the industry's interest. Unfortunately my job requires I cater to it.
Thank you again for your interesting words. Like I mentioned, I wish I could have industry reach out, rather than have to chase them around plant by plant.
Andy Germany (2); ashoktoshniwal (1); Blink (1); chtank (1); foridel (1); robert_cameron_jr (2); silvCrow (1); Sparkstation (1); Yusef1 (3)
