Previous in Forum: Vacuum Oil and Grease   Next in Forum: API 2W-60 Steel Plates
Reply For Coal Consumption Rate Per MW
12/17/2007 2:11 AM
The coal consumption rate per MW greatly depends on ash composition such as ash content,volatile matter content etc. For Indian coal with 42% ash and 12 % volatile matter,the rate is 350 MT/hr of coal for a 500 MW unit.This figure varies with capacity of unit too.For a 50 MW coal fired unit, it could be 40 MT/hr of coal reqt,whereas for an 800 MW thermal unit, we may be able to manage with 325 MT/Hr of Indian coal.
Re: Reply for coal consumption rate per MW.
12/17/2007 5:11 AM
And the question is what, exactly?
Good Answers: 243
12/18/2007 11:32 AM
Thanks rsn1.
PWslack, This is posted as a reply to my request in general discussion:
http://cr4.globalspec.com/thread/15305?frmtrk=cr4sd#newcomments
milo
09/14/2008 6:29 AM
coal consumpsion is 1 ton/mw/hr for 50 mw & 110 mw unit.
coal consumption is 0.8 ton/mw/hr for 210 mw & 250 mw unit.
and 0.6 to 0.75 ton /mw/hr for higher mw unit s.
Good Answers: 19
Re: Reply For Coal Consumption Rate Per MW
12/22/2007 11:27 PM
Are you trying to tell us as information or what are you asking?
The consumption of coal depends on the claorific value of the coal, the efficiency of the boiler itself and the lossses in your steam distribution system.
Good Answers: 243
12/23/2007 12:02 PM
Understood.
Here is my original request for Info:"
Anyone know of reliable source where I could find actual achieved megawatts to the grid per ton of coal combusted? Amount of kilowatt hours to mine a ton of steam coal? Amount of tons per hour mined?Efficiency factors for the conversion? I'm in North America, but confirmed engineering quality experiential factors from other installations globally will be helpful.
If there are underlying assumptions regarding factors of coal, process etc. please share.
Thanks to all."
I'm trying to determine the tngible deferred by a megawatt of noncombustion power vs traditional combustion power-tons of coal Not mined, Oil not consumed in mining etc.
Looking for engineering quality factors.
milo
Good Answers: 19
12/23/2007 1:01 PM
Now Understood. Actually i was confused as to whose thread this actually is.
By the way, do you have your :
1 . actual achieved megawatts to the grid per ton of coal combusted.
2 . Amount of kilowatt hours to mine a ton of steam coal.
3 .Amount of tons per hour mined?Efficiency factors for the conversion.
4 . Calorific value of your coal, ash & moisture %.
5 . Cost/Ton Coal.
6 . Operating Pressure of your Power Boiler(s) & Efficiency.
7 . Steam Turbine MW generation & Efficiency.
Good Answers: 243
09/14/2008 9:52 AM
I think the CR4 software bumped my original query and replaced it with that response. I thought that that happened on a what does cr 4 stand for post as well.
I just wanted to get some ball park figure to be able to calculate "offsets" based on replacement of coal fueled electricity.
Thanks
milo
Register to Reply 7 comments
Anonymous Poster (1); ducon (2); Milo (3); PWSlack (1)
