Previous in Forum: engineering drawing for the rotary cup burner   Next in Forum: TiN Vapor Deposition
17 comments
Small Steam Engines Design Required
12/17/2007 12:30 PM
Hi,
I am looking for designs or manufacturers to provide small steam engines that can run a generator for electricity for hospitals in Africa.
The idea is to use the hospital and other waste to produce electricity
All suggestions welcome
Pathfinder Tags: steam engine generator
Good Answers: 18
Re: small steam engines design required
12/17/2007 3:24 PM
Try this site for plans.
Re: Small Steam Engines Design Required
12/17/2007 4:15 PM
Why steam?
Steam has proven to be dangerous and very nasty.
How do you want to handle corrosion and supplying water?
Steam is for big systems.
Go for Stirling or Erickson,
Gwen
12/18/2007 12:49 AM
I suggest you try used steam turbine marine generator systems bought used from ship breakers. Everything will be there all you wil need is a suitable boiler. Alternatively, same source can supply excellent diesel generators which can be converted to run on BIO-Diesel see: journeytoforever.com
the water supply problems and technical knowledge required to run a steam setup does way pretty heavily against their use.
In rebuilding diesels can be improved significantly by using aftermarket high performance parts.
I think the best option might be wind generators. you can locally manufacture the blades, hubs can be converted from automotive differentials and the generator portions can be ganged and geared auto alternators or hand made modern types like those briggs & Stratten make in the US.
12/18/2007 3:15 AM
I think he is looking for a systainable product which can be made in series for serveral hospitals over the world.
The best is to do them all the same. Recovery units would be all different, all needing diffrent spare part sets, training,...
This is exactly where it all went wrong in the past: a nice set was delivered and worked for some years, than it got broken and the organisation who supplied it could not help them as the unit was an already old unit.
What they need is something they can easely make from standard equipment, that can run on all type of burning fuels and spare parts can be organised when needed.
Original guest: create yourself a nickname and come in the discussion.
12/18/2007 5:22 AM
Sustainability is difficult, cause it implies that people need something AND have the means to maintain (sustain) it, so it should have a clear added value, that gives you more than the only the effort needed to sustain it.
In this respect, we designed a handpump that is very durable and can work for 25+ years from 1 to 100 m deep, without spare parts (indeed the main problem were to find these), we called it the Afripump and are now promoting it in Africa. see www.handpump.org
Thanks for comments
Paul van Beers
12/17/2007 9:10 PM
"I am looking for designs or manufacturers to provide small steam engines that can run a generator for electricity for hospitals in Africa."
Mike Brown's Steam Engines & Kits Also information of associated products.
12/18/2007 4:50 AM
Thanks, I checked the site and YouTube video, that's exactly what we are looking for, now lets promote this in the developing world and mass produce it.
i will put it on my websites www.watsan.org and www.watsan.com
Paul
09/05/2008 10:32 PM
Dear sir
we can supply this engine or generator
Please send more detail to my email
09/05/2008 10:45 PM
"Please send more detail to my email"
Tis not I, Stirling Stan that wants a small steam engine. It is the original poster, Paul WatSan That is seeking information. Please read the thread next time to determind who wants what and who is making suggestion to fulfill that inquiry.
12/18/2007 1:55 PM
Be sure and include one-piece, drilled venturi steam traps for maximum efficiency and minimum maintenance. I have info available.
John
12/18/2007 3:17 PM
I got a reply on a separate thread about steam generators that I think will solve your problem. Forwarded by a "Guest", whom I thank. Lynx Motors. They modify lawn mower engines, build small boilers and have a small alternator for power. It is cheap and first looks are promising.
Good luck,
James
" adapt, improvise, overcome "
12/18/2007 4:56 PM
you can take the ideas from lynx motors and apply them to any engine. I think you will want to use a multi-cylinder engine so that it will be self starting. Single cylinder units need to be turned to start running. V series engines are more prone to start with the application of steam as the timing allows the introduction of steam to push one cylinder or the other.
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
12/18/2007 5:38 PM
I understand your point. Everyone please share your thoughts on the following.
Hypothetical scenario: I live in an isolated area. I have a 5HP lawn mower engine that is steam driven, wood fired. What kind of transmission system would you use to drive a 5500 Watt generator head.
James
12/19/2007 5:25 AM
Double acting cylinder arrangement or single? This would be the factor for the gearing as you would double the horsepower by using a double acting cylinder arrangement. Are you using an A.C. generator head, or D.C. If A.C., will need to know the number of poles in the unit to determine the "sweet" speed for the production of 60 cycles. Typically it is 3600, 1800, or 900 RPM. If D.C. you would need to check the data plate. Stepping up the armature speed reduces the torque available from the engine to turn the armature.
What kind of transmission? I would recommend a spur gear unit. driven in reverse.
01/02/2008 12:44 PM
I could manufacture a small steam engine if you would like. Do you have designs or plans ? If you are still in need of someone to produce these for you please let me know. My email is thayersjobshop at yahoo dot com. Please let me know asap I am also willing to speak on the phone if you would like.
08/28/2008 11:53 AM
did you find
http://www.strathsteam.com/page6.html
it would seem to fit
Mike
09/02/2008 8:14 AM
HI
WHAT CAPACITY OF STEAM ENGINE YOU ARE LOOKING FOR?
DO YOU HAVE THE STEAM AVAILABLE WITH YOU?
OR YOU REQUIRE THE STEAM BOILER ALSO?
PLEASE REVERT BACK
Register to Reply 17 comments
Anonymous Poster (5); Bill (1); generator-china (1); Gwen.Stouthuysen (1); hastingselectric (2); joltnjny (1); Paul WatSan (2); RicinCinci (2); Stirling Stan (2)
