The secret may be an unstable electrical field in the coating chamber. The process is patented by Teer Coatings Ltd of the UK, who build the machines to do it, or will offer a contract coating service.
I think you are right for a plasma deposition it would be very beneficial to have some instability or oscillation. This can either be electrical field or magnetic field or density, also ion or electron cyclotron movements or any other of the many plasma instabilities.
(There is a book from Chen on these.)
In the simple pressure and temperature driven coating I talked about there is no electrical action at all, only temperature and pressure!
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
