Previous in Forum: TiN Vapor Deposition   Next in Forum: CEO- Matrix (Pvt) Ltd
13 comments
Good Answers: 12
Air Flow Measurement
12/18/2007 3:56 PM
I have a tricky one. I need to measure the rate at which air is rotating around a moderately small cylinder (~3 inch in diameter tube). The air could get up to 10s of k RPM, possibly even more. The hard part is that I need this to be as unobtrusive as possible. I am seriously trying to avoid introducing any additional friction or turbulance into the system.
The measurement doesn't need to be super precise. A good estimate will do. To add to the complexity the air in the cylinder will be changing teprature over a roughly 20 celcius range and whatever sensor I use has to be immune to a roughly 20kV ionizing dischange that will be happening in the tube.
I am hoping that one of you rocket scientists out there will have some ideas I could use. FYI, this is for a physics aparatus for measuring heat flow in a vortex.
Thanks everyone
A robot must risk his neck for his brother man, and may not cop out when there's danger all about. - Isaac Hayes' First Law of Robotics
Re: Air Flow Measurement
12/19/2007 2:24 AM
It certainly is a tricky one. What comes to mind is:
Charge the air with a dilute concentration of dust (preferably black or reflective). Arrange for stroboscopic lighning at a know and variable frequency. Make some sort of photos. Try to track particles. Divide distances travelled by time between strobe flashes.
If the timing and particle concentrations are right, some individual particles can be well tracked if the distances travelled are neither too long nor too short.
Constant change is here to stay!
12/19/2007 5:18 AM
Best I can suggest is a very small Pitot tube. I think gliders use a sort of reverse Pitot tube.
Are you sure you'll only get temperature changes of 20oC: have you looked at Ranque Hilsch vortex tubes. The people trying to figure out exactly how these work must have tackled this problem.
Does it matter if you affect the temperature in the device? I'm thinking about a flat, flush mounted "heatsink" which is being heated by a well regulated source; a temperature sensor in the same device should give you a good indication of air speed. You'd need to do a lot of calibration, and, you might need a reference temperature sensor next to or just "in front" of it.
Good luck! Please let us know how you get on.
12/19/2007 6:51 AM
drobertson:
If the cylinder could be mounted so that it's free to rotate, it should tend to rotate with the air. The force required to restrain it will then be proportional to rotational velocity. As with any other approach, calibration is key.
DickL
Good Answers: 12
12/19/2007 8:50 AM
With the current setup the tube is fixed. I may be able to modify the configuration to allow some movement. I could possibly incorporate a strain guage to measure the torque on the outside tube. The Pitot tube is also a good idea, but it would neeed to be carefully incorporated in the design to reduce the turbulence it would create.
Thanks for the ideas. This is a tough one and your help is getting me thinking.
-Doug
12/19/2007 9:33 AM
If any intrusion is possible then why not use a micro bead thermistor?
The temperature sensing head is only 1 mm diameter, so its effect on air flow disturbance should be negligible.
Failing that perhaps a simple hot wire anemometer sensor could be used, as the hot wire is once again tiny in size.
Just thinking out aloud here hope it helps?
John.
12/19/2007 9:38 AM
You could try using a constant temperature anemometer with another temperature gauge to compensate for the low frequency overall temperature change. The 20kV ionizing discharge may play havoc with that, though. Or, you could use ink drops to visualize the flow along the walls. Basically in this case you would just add a grid of ink droplets along the wall of the cylinder and see how they are skewed by the flow.
12/19/2007 11:10 AM
drobertson:
You might also consider using a VERY small hole in the cylinder wall coupled by tubing to a pressure sensor. Pressure coupled from a hole perpendicular to the wall may be dominated by Bernoulli, while one tangent to the wall may provide positive pressure. A little experimentation and, again, calibration would be called for.
Best regards.
DickL
12/20/2007 4:49 AM
Good idea DickL
However, will a 20C shift in temp. give errors in the pressure reading due to the changes in air density. I susjest introducing a thermocouple into the system. Temp reading taken with pressure reading to increase accuracy.
RPM will be a function of pressure and temp.
Regards
Jon
Good Answers: 12
12/20/2007 9:00 AM
We will have a pretty good system for reading temp. I can use that for making adjustments to the RPM measurements.
This is going to be a bear to calibrate. :-(
-Doug
12/20/2007 9:23 AM
Better still how about using a microbridge air flow sensor, taking the microbridge out of the sensor and mounting it flush to the inside of the tube...
This would give you a temperature compensated mass flow measurement of air flow, which shouldn't need re-calibrating, assuming the air flow is reasonably laminar when flowing across the tiny sensor...
I've used hundreds of the Honeywell ones before now and they are remarkably accurate even when exposed to temperature and pressure changes. Even when hacksawed open to remove the micro-bridge sensor?!
John.
Good Answers: 12
12/20/2007 9:51 AM
Interesting. That one would fit my "Simple for me to implement" standard. I am lazy and hate getting into overly complicated designs if I don't need to.
Do you have a link for sourcing these and the specs I could look at?
Thanks
Doug
12/20/2007 10:46 AM
Farnell stock them as standard parts worldwide...
here's a link (hopefully) _
http://uk.farnell.com/jsp/search/browse.jsp?N=500004+1002015&Ntk=gensearch_001&Ntt=airflow+sensor&Ntx=
Good luck - John.
12/25/2007 10:20 AM
Hello,
If you have an open view from the end, I would suggest introducing a light particle such as a small piece or snip of paper and then use a high speed camera, or even a strobe light might do to check the advance of the paper snip per 1/1000 second or so. Hopefully the rotation in that time is less than 1 rotation. Even if it is more you would still know its speed if you have a ball park figure anyway.
Without open view a glass insert and the camera would still do.
Hope that helps.
Register to Reply 13 comments
Anonymous Poster (1); Bancha (1); DickL (2); dovy (1); drobertson (3); Electroman (3); Jonny5 (1); Randall (1)
