Previous in Forum: USB widgets   Next in Forum: What More Can Go Wrong With Hotter Earth?
HVAC Clean Room Design
12/20/2007 6:30 AM
i want design ISO 5 (class 100) for electronic industry for that what will be the supply & return duct velocity.
Re: HVAC Clean Room Design
12/20/2007 8:56 AM
So what are you doing yapping on a forum? Get to work. Or do you have a specific question? If so, please post it because I don't know what you need from your one sentence request.
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
12/20/2007 9:53 AM
I suggest you turn that project over to an expert!
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
Good Answers: 101
12/23/2007 8:58 PM
What's your required volumetric flowrate? Without that, it's impossible to know your required duct size, fan etc.
12/23/2007 9:55 PM
To Guest;
You might get good answers if you would provide intended use, user requirements, size of working area, of course, your specs (class 100), number of personnel that will be expected in the area (full or part of the time), amount of equipment (to calc. BTU's), flow specs like mentioned by my other colleague, and generals like temp ranges, airlocks, windows, doos, movement, air changes required......................etc.
Anonymous Poster (1); DVader1000 (1); ronald (2); shogun7 (1)
