So, if as popular theory holds, all the ice caps are melting and as they melt the sea level is supposed to rise. How high will it rise or, will it stay the same due to the fact that frozen water takes up three times the space as liquid. As glaciers are supposed to be about 7/10ths below water. Or will the sea level drop. This is similar to the boat in the lock question. You could consider that your boat is an iceburg. What do you think??? Should we build sea walls along both coasts....
