Previous in Forum: The odd ball   Next in Forum: Renewable Hydrogen from Ethanol by Autothermal Reforming
Retaining Wall Geogrid ?
12/22/2007 9:23 PM
I am working on a retaining wall that is 6' tall out of Diamond Pro retaining wall block made by Anchor wall. What type of geogrid would be best for this wall? The soil is clay but I will be using a compacted arregate. The local block supplier offers 2XT and 3XT geogrid but I really don't know the difference.
Good Answers: 230
Re: Retaining Wall Geogrid ?
12/24/2007 1:20 AM
Hello wvgmc1,
"I really don't know the difference."
Nor do I, but do what I do, look up the Manufacturer's Website.
Look on Mr Google's fine Search Engine, there are many references.
Have a look here:
http://www.anchorwall.com/Company_Information/Company_Information_Index.asp
Select your proposed product, and you have the info.....
Good Answers: 15
12/24/2007 9:22 AM
Either Contact the manufacturer or the suppier you bought the blocks.
Either one should be able to tell you which grid you should use.
Actually the Manufacturer would be best, because they may prefer a different geogrid than your supplier is offering.
scotchdrnkr
12/24/2007 1:13 PM
http://www.geocheminc.com/pdf/MARV_Properties.pdf
i Work for allied concrete we produce dia pro strait and bev i recommend the above site
12/24/2007 1:16 PM
sorry i forgot this link as well
12/24/2007 1:16 PM
http://www.geocheminc.com/geogrids.htm
12/28/2007 12:00 PM
If you want a Retaining wall safe in all water-soaked seasons then you should go for foot shaped Precast concrete blocks say 2' wide
The foot should be projecting in about2',the wall(leg) 6' At transition from foot to leg you should have reinforcements--to resist toppling moments from slushy mud on vertical portion while it is bearing down on the foot. To take care of concave bends in the Retaining Wall plan--foot should taper down to say15"(from2'). Only SOME.
And between2' wide sections -purposely leave gaps for slush/seepage to leak out (weeping holes).
Let us not worry about 2XT/3XT
02/12/2008 6:02 AM
For retaining wall better to use uniaxial geogrids as the force is mainly in one direction. I think Colbond company has a nice design software for it. You may contect them. For general information on geogrids, geocomposites, and all geosynthetics check this blog.
http://geosynthetic.blogspot.com/search/label/geogrid
Register to Reply 7 comments
Anonymous Poster (4); MUKULMAHANT (1); scotchdrnkr (1); Sparkstation (1)
