I just draw the shaft on my vessel for ABS inspection. The proplusion system of this vessel consists of intermmedaite shaft, two in line pedestal bearing, and tail shaft. the pedestal bearings were renewed completely. The shipyard are doing alignment, but the face to face reading bewteen the main engine gearbox flange to the intermmediate shaft flange and between intermmediate shaft coupling flange to tail shaft coupling flange are in the area of .5 mm difference between top and bottom and .1 mm differnece port/stbd
