Previous in Forum: measurement of swg   Next in Forum: ABS ABID
Expansion between gas pipe
12/24/2007 7:20 AM
Hello,
I would like to ask about thermal calculation between gas carring pipe.
Normally we fixed expansion bellow in horizontal pipe.
My few specifications are as under:
Pipe carry: B.F.gases for burning (from Blast furnace to Burner)
Pipe dia: 1500 mm (Spiral welded M.S.pipe)
Temp.: 40 deg.C.
Length of pipe : 25 Mtrs Horizontal & 35 Mtrs.Verical.
Please suggest me location for Expansion bellow on this pipe line.
My E mail: prabhakar.aher@rediffmail.com
Re: Expansion between gas pipe
12/25/2007 2:12 AM
Thermal Expansion (inch) = Length of pipe (ft) x Linear thermal expansion of mild steel (inch/100 ft)
Linear Thermal Expansion of mild steel can be easily found from a material tables by knowing the temperature changes (min. & max.).
12/26/2007 5:01 AM
I am very much thanking you !
I want to know the exact location of expansion bellow in between horizontal pipe line,
Can you suggest me please !
Regards,
Prabhakar Aher
12/26/2007 6:27 AM
You are kindly requested to send the detailed design drawings to include type of supports and its locations.
12/25/2007 9:05 AM
Gland packed Telescopic Joint is your answer.
Wrap Graphited Asbestos rope--or even manilla/Hemp say 10x10mm and you should get leakproof expansion joint. Your total movement will be less than 5 mm --ever
Joints where?;
One on the Horizontal leg---middle of the run rigidly anchored-with 2 telescoping in/out dia 1500.
On the Vertical Run -- One, right near top delivery. Rest allowed to expand/contract in non-anchored Tower support in which it can expand/contract loose.
12/25/2007 5:14 PM
Hope not being suggested for use in USA, given use of Asbestos Rope. Would a Kevlar product work?
12/29/2007 11:06 PM
Cotton/Manilla/Polyester/Nylon all will do.Kevlar--so expensive! Smear Graphited Grease.
Good Answers: 19
12/26/2007 3:13 PM
After you calculate the expansion based on Mr.Abdel Halim Galala go to Venn/ Ayvaz site and download their Expansion Bellow spec sheet indicating installation. There you will find formulas to calculate Fixed & Sliding guides for both horizontal & vertical installation. Follow it.
Abdel Halim Galala (2); Anonymous Poster (2); ducon (1); MUKULMAHANT (2)
