Does anyone have a formula for the evaporation of water given 1) surface area, 2) barometric pressure, 3) ambient temperature above the surface of the water, 4) temperature of the water, 5) humidity of the air above the water? For the temps, either f or C will do. For area, either feet or meters (square) will do. For barometric pressure, I know Inches of Mercury, rather than millibars, but if you have the conversion formula, its time I commit that one to memory also.
I'm not looking for 12 decimal place accuracy, just a good value for calculation of water volume loss over time in a fairly large (for a Jacuzzi, anyway) pool of water that seems to require replenishment too often to account for by evaporation alone. But since it is heated 24/7 to 90-92 degrees f, and the building it is in cycles from ambient outdoor to 70 degrees f every 24 hours, with humidity staying in the 20-30% range, I can't assume away evaporation as the cause. I can plug in all the variables, including the changes, using averages over a 24 period, and averaging for the year, so those inaccuracies can be fairly well accounted for.
Thanks
Micah
