Previous in Forum: pressure vessel   Next in Forum: Powder Coating vs. Galvanizing
pva
12/30/2007 8:35 AM
what is treatement on pva used in sizing department in textile industry when it comes in effluent treatement plant.
Re: pva
12/31/2007 12:44 PM
You want to remove PVA you mixed with water?
  • You now wish to separate from effluent water going out--becuse somebody objecting?
  • How may LITRE/Kg pva in how many LitresWater?
  • Temp.?
On hearing your confirmation -we will return with solution/s.
Re: pva
12/31/2007 11:36 PM
I want to make sure we are talking about the same material. PVA is poly vinyl alcohol? PVA is used in the manufacture of certain fabrics to make them stronger and for other reasons. PVA, as with all fibers, is usually coated with a sizing but the sizing will vary depending upon the company that made the fiber and the end user. And, there are times when more than one sizing is used on the fiber. Formulations vary widely so it is best that you speak with your fiber supplier or send the fibers to a laboratory for testing.
I applaud your effort to reduce the impact on your effluent plant. Many companies might not be as diligent as you.
Does this information help?
Re: pva
01/02/2008 4:30 AM
PVA:
  • Polyvinyl Alcohol?
  • Polyvinyl Acetate?
MUKULMAHANT (1); PWSlack (1); Walter Mitty (1)
