My sump pump was running every couple of minutes and I could hear the water flowing back into the sump from the outflow pipe. When I disconnected the pipe to inspect the check valve (which appears to be fine), I could hear and feel a constant suction from the downstream side.
I cannot figure out what is causing this suction, but I have a feeling it is causing the check valve to lift and allow water to spill back into the sump. (I decided to replace the check valve and pump anyway. I don't have a water hammer problem, but I also installed a water hammer extension to which I am thinking of attaching a check valve to allow air back into the pipe as the suction demanded.)
What is causing this suction?
Thanks
