I'm looking for a part that I thought would be pretty commonly used and a standard part manufactured by several manufacturers. I can best describe it as a tube insert with a rod end on the end. I've included a pic of one I drew to make the description more clear. One end fits into a round tube (and has a hole to rivet or bolt it in place). The other end is flat to fit into a slot and has a hole for a pin or shoulder bolt. Depending on the use, it may pivot around this hole.
Has anyone seen a part like this and can anyone recomend a manufacturer, distributor, or resaler?
