Previous in Forum: Moisture measurement in instrument air   Next in Forum: Wireless Technology in Instrumentation
Is it OK if Cat6 cable connected to RJ45 sockets?
01/03/2008 11:10 PM
Fellas,
Far as I know RJ45 is suitable for CAT5 or CAT5e twisted cable. Is it ok for CAT6 cable?
thanks&regards.
Re: Is it OK if Cat6 cable connected to RJ45 sockets?
01/04/2008 12:13 AM
Yes. Basically the same as CAT5e (same purpose) but better specs.
Good Answers: 97
01/04/2008 12:43 AM
Are you using RJ45 connectors because you cannot get Cat6? It should work.
If you use Cat6 cable because you cannot get RJ45, it will work but you will be limited to Cat6 speeds and length restrictions.
01/04/2008 1:28 AM
Dear all,
thank for the helpfull-answer.
may you all have nice days there.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
01/07/2008 6:44 AM
The issue is what performance you want from your link. If you want Category 6 performance then ALL components of the link must meet that standard including patch panels, cables and connectors. There are Category 6 versions of RJ45 connectors available which must be used to get Category 6 performance. Your can physical connect lower rated RJ45 connectors, but they will downgrade link performance.
01/09/2008 12:50 PM
I looked into this for a think tank build. What I read was in theory CAT 6 is twice the efficiency of CAT 5. However, if any component in the chain is less than CAT 6, the system drops to whatever the "choke piont is. IE. patch cord, connectors, or punchdown board.
01/11/2008 10:54 AM
You are correct.
Register to Reply 6 comments
Abu Khansa (1); Anonymous Poster (1); Chankley (1); Hendrik (1); Kilowatt0 (1); SouthernJag (1)
You might be interested in: Cable Assemblies, Relay Sockets, Cable Laying Services
