Previous in Forum: Determination of sintering temperature   Next in Forum: career in oil and gas sector
24 comments
3D Printer
01/06/2008 1:36 AM
Hi, i would like to ask one question which is can 3D printer fabricate metal based powder such like Aluminium powder?? Thanks for answering my question..
Re: 3D Printer
01/06/2008 11:30 PM
china trade , skype=officeings
http://hi.baidu.com/officeings
Re: 3D Printer
01/06/2008 11:44 PM
Is this even possible? Haven't heard of it? I've heard of casting based on a 3d printed mold (ABS / Photopolymer) before, but not direct aluminum powder printing..
Pray as if everything depended upon God and work as if everything depended upon man. - Francis Cardinal Spellman (1889 - 1967)
Re: 3D Printer
04/16/2011 1:19 AM
Hi..Can you tell how its possible to use 3D printer for investment casting or lost wax casting. Thank you.
Re: 3D Printer
04/16/2011 2:12 PM
shrey: A 3-D model could be made in wax or an investment cavity made from a high temp. matrix ready for firing and casting. Alternatively make a wax model and then embed it in a plaster matrix and burn out the wax. Either way will work depending on the specific design of the finished part.
Good Answers: 94
Re: 3D Printer
04/18/2011 4:34 AM
I saw 3D wax printing at a show earlier this year & it looked pretty good. Ther are a number of companies now offering printing like this.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
Re: 3D Printer
01/07/2008 4:49 AM
Hi, She!
I'm not sure I understand the question.
Are you trying to use a 3D printer to create a metal based powder?
Or are you trying to use the 3D printer to cast from or print with metal powder?
Mark
Re: 3D Printer
01/11/2008 3:20 AM
Hi, Mark!
I try to use Z406 3D Printer to ''print'' metal powder which is Aluminium powder. It's not 100% pure Aluminium. It's 95%. Do you get it? I'm not sure got people did it before or not. Could you please tell me is it possible to do it? Do you know where can i get the infomation about it??Thank you very much
Good Answers: 94
Re: 3D Printer
01/11/2008 4:33 AM
Don't you need some sort of binder in the powder to 'stick' the model together. The only 3D metal printers I've encountered produced a very fragile 'green' model which then had to be sintered to give it some strength.
Re: 3D Printer
01/14/2008 2:07 AM
Thanks for replying me.. Yes, I need binder which is Zb56 from Z-Corp to 'stick' the powder together..I would like to ask you the only 3D metal printers you've encountered is which model? Is it from Z-Corp? Z-406 3DPrinter?
Good Answers: 94
Re: 3D Printer
01/14/2008 4:23 AM
It was Z-Corp but I can't remember the model.
Re: 3D Printer
01/11/2008 8:52 AM
Hi, She!
http://www.google.ca/search?hl=en&q=model+%22powdered+Aluminum%22&meta=
and
http://www.google.ca/search?hl=en&q=binder+%22powdered+Aluminum%22&meta=
Good Luck! From what I see in these two Google lists, I think this is possible and you are not in new territory. If you find an answer in here, and it works, let us know.
Mark
Re: 3D Printer
01/14/2008 2:15 AM
Thank you very much for your help..I'll try my best..
Re: 3D Printer
01/26/2008 8:37 PM
Hi Mark,
I mix 50% Al and 50% ZP102 powder. I try to fabricate using ZP406 3D Printer. I discovered that it really works. Since it works, now, i'l try 60% Al, 40% ZP102 powder and 70% Al, 30% ZP 102 Powder. Do you think i should continue with this ratio? Do you know from where i can get these information? Thank you very much..
Re: 3D Printer
01/27/2008 5:53 AM
Hi, she!
At this point, I have no more opinions...except that you have won your first victory in this arena on your own.
By all means, continue exploring this approach. You are getting lots of expert help.
You will, if you continue in this direction, definitely become the "go-to" person in CR4 in this area of expertise.
Mark
Re: 3D Printer
01/27/2008 12:06 PM
What is your end goal.? I have a 3D Zcorp 510 and would not mind experimenting.
Re: 3D Printer
04/24/2011 2:17 AM
Hi She..
Can u tell me why ur tryin this mixtures..? And for which application u want to use it..coz if u knw there are also SLS n SLM technologies which are suitable for metals printing rather than 3D printing.
Re: 3D Printer
01/26/2008 10:38 PM
The "Whizzit uses Al powder with a minimum (?) urethane binder. Result is an excellent part with properties approaching solid metallic Al!
Good Answers: 94
Re: 3D Printer
01/07/2008 6:01 AM
There are 3D printers that will produce parts in metal but not in aluminium. I think they use a copper based alloy.
Z Corp make a 3D printer that will produce a ceramic mould that can be used to cast aluminium parts.
I have also seen demonstrated a 3D printer that produced parts in wax so that they could be used to produce investment castings.
Re: 3D Printer
04/24/2011 1:54 AM
Which was that company and tell me its model if u remembered,3D printer that produced parts in wax which can b used for investment casting...
Re: 3D Printer
04/24/2011 12:45 PM
The Whiz-it is not currently in production. Resumption is unknown.
Good Answers: 94
Re: 3D Printer
04/25/2011 1:00 PM
I saw this at a show in February, I'll have to trawl through the show brochure tomorrow to see if I can find the company. Looking on the web, this company has a 3D wax printer.
Canada - Member - New Member
Good Answers: 11
Re: 3D Printer
01/07/2008 7:03 AM
Try a Google search for aluminium laser sintering.
www.eos.info seems right if you have the money.
Re: 3D Printer
01/07/2008 12:19 PM
"Hi, i would like to ask one question which is can 3D printer fabricate metal based powder such like Aluminium powder??" NO, But..."
With a "Whizzit" 3D Desktop Printer you can make a semi-flexible plastic mold. This is filled with an aluminum power filled epoxy or similar binder. The result is a metallic gear or other object with good wear characteristics.
This results in a prototype part adequate for testing an assembly prior to manufacture of actual final application.
Re: 3D Printer
01/07/2008 8:36 PM
That's way cool! Too bad the Euro is exhorbitantly high now. Anyone know of any American companies into laser-sintering for metals?
Register to Reply 24 comments
Anonymous Poster (2); gigaconcept.com (1); heath71 (2); MarkTheHandyman (3); Nigh (5); she (4); shrey.enr (3); Stirling Stan (4)
