Previous in Forum: Reefer Van and Cold Strorage Rooms Calibration   Next in Forum: Semi Trailer Landing Leg Test
LATHE MACHINE
01/06/2008 11:18 PM
How can we improve the effeciency of LATHE MATCHINE?
Good Answers: 230
Re: LATHE MACHINE
01/07/2008 12:27 AM
Hello Mohammad Akmal,
You haven't stated which make, model of lathe you use, or what you are machining.
You may have a model-maker's lathe or a giant lathe for turning steam turbine shafts.
You may be machining steel, brass, wood or many others.
So, I am going to make some assumptions here:
  1. You are machining cold-rolled or silver steel shafts
  2. You are wanting to increase output of many parts the same
Machining steel faster:
  1. Get an Auto-feed facility for the lathe
  2. Use an auto-close/opening chuck
  3. If shaft is heavy, use moveable electric crane on rails above the lathe, to bring work in/out
  4. Use better and sharper tool cutting tips
  5. Use a higher turning speed
  6. Use DC Motor to power the lathe, with controlled variable speed by computer
  7. Run your lathe 24/7/365, using different operators, of course
  8. If your finished work is extremely fine finish, it is sometimes faster to use 2 or 3 other lathes, to do the rough work, and have your best lathe to finish off to all required dimensions
  9. Try and use better coolant, and more of it, pumped across the cutter tool and work area
Those are basic things, as I said, I have made some assumptions.
Advise further if you need it.
Kind Regards....
Re: LATHE MACHINE
01/07/2008 12:51 AM
add a digital tech in it!!!!!
Register to Reply 2 comments
