I was hoping someone can anwser the following question.
When calculating average power in an AC circuit, is it the same as calculating the maximum power dissipation. If yes, would I then use Thevinis Theorem to assist with the calculations?
In any AC Power transfer circuit, the maximum power transfer is when the source impedance equals the load Impedance, at the frequency being transferred - This is the same as for DC circuits.
Because in AC circuits, the DC resistances remain the same, but AC resistances (Impedances) alter with frequency, AC calculations can be extremely complex, particularly in cases of "unusual (non-Sinewave) waveforms" and/or multiple frequencies.
As you can see, on that web-linked page, DC examples and calculations only are given.
Does that answer the question you intended?
Kind Regards....
Maximum Power Transferred vs Source and Load Resistance/Impedance
In the diagram above, power is being transferred from the source at voltage V and fixed source resistance RS, to a load with resistance RL resulting in a current I. By Ohm's law, I is simply the source voltage divided by the total circuit resistance:
The power PL dissipated in the load is the square of the current multiplied by the resistance:
We could calculate the value of RL for which this expression is a maximum, but it is easier to calculate the value of RL for which the denominator
is a minimum. The result will be the same in either case. Differentiating with respect to RL:
For a maximum or minimum, the first derivative is zero, so
or
In practical resistive circuits, RS and RL are both positive. To find out whether this solution is a minimum or a maximum, we must differentiate again:
This is positive for positive values of RS and RL, showing that the denominator is a minimum, and the power is therefore a maximum, when
RS = RL.
You can also demonstrate maximum power transfer graphically by plotting the power transferred (y-axis) against the load resistance (x-axis) for a given fixed source resistance. Hint: For convenience, set E = 1 volt, RS = 1 ohm, and plot
PL vs RL for 0 <= RL < ∞.
Maximum Power Transfer vs Efficiency
The condition of maximum power transfer does not result in maximum efficiency. If we define the efficiency η
as the ratio of power dissipated by the load to power developed by the
source, then it is straightforward to calculate from the circuit shown above that
Consider three particular cases:
If Rload = Rsource, then η = 0.5.
If , then η = 1.
If Rload = 0, then η = 0.
The efficiency is only 50% when maximum power transfer is achieved,
but approaches 100% as the load resistance approaches infinity (though
the total power level tends towards zero). When the load resistance is
zero, all the power is consumed inside the source (the power dissipated
in a short circuit is zero) so the efficiency is zero.
"The Maximum Power Transfer Theorem states that the maximum amount of power will be dissipated by a load resistance if it is equal to the Thevenin or Norton resistance of the network supplying power."
This is correct for DC circuits or AC circuits supplying only resistive elements. In case of impedances, the maximum average (real) power will be transferred from the source to the load if the load impedance equals the conjugate of Thevenin impedance of the circuit.
