System
Pump at source of product - Head 50m and capacity 200m3/hr
Pipe Length approx 64m SS
90 Deg elbows - approx 10
height from pump discharge to destination is approx 16m
destination has control valve used to control two other liquids for flow and temperature.
Density: 1005 Kg/m3; Viscosity: As per water; Temperature: 80˚C; Pressure in line: 2 Bar; Max Flow Rate: 120 – 130 m3/hr; Average Flow Rate: 90-110 m3/h
Problem
I have had a Instrumentation Company spec a Mass Meter (straight through) of size DN80 (3") that will match the required flow rate of the current system. The pressure drop across the Instrument is 0.1 bar, the only problem that I see is that the line size is for the most part DN150 (6") and as per system specs above, I think that this will cause too much of a restriction in the line (drop from DN150 to DN80) for the system to function as it does currently. I haven't got the tech knowledge to prove that this is or is not the case. So I am looking for some evidence that this will or will not work if new mass meter is installed in line. The calculator that the instrument Co. uses is based on required flow rates etc and does not take into account the drop from DN150 to DN80. Based on the system above and if the line was to be reduced from DN150 to DN80 would this effect the system??? Also what is a good guess at the pressure drop that will be created if introducing concentric reducers to allow for new mass meter?? If there is some one that can help me out I would be very grateful.
Thanks
