Previous in Forum: CAT engine ignition system   Next in Forum: Material Elongation
15 comments
Borehole Depth
01/09/2008 6:04 AM
Please can anybody tell me the max. depth of a water borehole? Our present borehole is just 100m deep and we are experiencing contamination with oil. Bazamfare- Iro
Re: Mechanical Engineering
01/09/2008 6:17 AM
There's no real limit. A factory in Dagenham has four water boreholes that go in excess of 500ft below the surface.
Good Answers: 230
01/09/2008 7:14 AM
Hello barhama
In New Zealand, some areas have boreholes over a kilometre deep.
Bore wells 30 miles from here, are commonly over 700 feet deep.
Where is the oil coming from?
Are there oil wells locally?
Is a Workshop, Petrol station, or Oil depot "upstream" in your district?
If so, they may have a leaking underground tank.
If you drill deeper, you probably will require a special "deepwell" type of submersible pump, to raise the water to the surface.
Kind Regards....
01/09/2008 11:32 AM
Thanks. You are great. Actually we have an oil depot 10km upstream, and the pipeline transversed our community. Once more thank you as you have provided us with a solution i.e we shall go down further to may be 200 or 220 m.
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
01/09/2008 12:38 PM
barhama,
Just going down further may not necessarily solve your problem...
You must make sure that the well casing itself is installed properly, and the well annulus fully sealed & grouted properly, otherwise, when you drill deeper, the oil contamination will seep down right around the well casing to whatever depth you terminate & screen the well at.
Just my $0.02...
Good Answers: 50
01/10/2008 1:04 AM
The JMAN has a really good point!!!
The USGS and EPA several years ago were drilling wells to test ground water for contaminants. They found if they continued to drill deeper they could hit a presently uncontaminated aquifer, and then contaminate it with the water from the contaminated aquifer above!
Good Answers: 247
01/10/2008 12:08 PM
just your $0.02... but worth thousands of dollars. Very good advice.
Good Answers: 266
01/09/2008 8:07 AM
It is possible that you can find oil at that depth. Most likely it would be mixed with water. I could be from ground contamination. Dumping of contaminates on the surface could seep down into the water table. If Oil wells are in the area and proper well heads were not in place to protect ground water could cause the problem. Or leakage from the pump jack at the surface due not being properly maintained.
Good Answers: 19
Re: Borehole Depth
01/09/2008 10:00 AM
barhama,
In the State of Maine, there are dozens of bedrock wells used for water production that are greater than 1,000 feet deep, with some nearly 1,500 feet deep.
Just my $0.02...
Re: Borehole Depth
01/09/2008 11:19 PM
The max. of water drilled well is deeper than 3000 feet.
You can refer this link to understand more about water drilled well.
http://en.wikipedia.org/wiki/Water_well#Drilled_wells
Good luck.
Nature is unlimited, human's knowledge is limited
Re: Borehole Depth
01/09/2008 11:27 PM
Good news.
I can tell you how to seperate the oil from water--Electrically.
You will be rich/happy/powerful and have lots of water to boot!
Re: Borehole Depth
01/10/2008 2:11 PM
This I am interested in - please tell me more!
To be or not to be - that's pretty much all there is...
Re: Borehole Depth
01/11/2008 9:21 AM
We discussed ElectroCoagulation many a time before ,right here in CR4.
Just tell me % or ppm Oil in Water.
I have hands -on experience in suchEC separation techniques:
Good for OIL/WATER/Chemicals separation
Good for getting safe drinking water out of ANY water
Good for separating bulk of sewage and making water safe to discharge to rivers
Please GOOGLE and deep into it.
MM
<mikemahant@hotmail.com>
Re: Borehole Depth
01/11/2008 9:27 AM
Man, did I miss the boat - I never saw...
Seriously, thanx!
I don't have a specific application but water is so precious here that I would like to find out about more.
Your experience is from what? Well driller or science? (both great!)
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
Re: Borehole Depth
01/10/2008 10:47 AM
JMAN and vermin bring forth an important point concerning possible degradation of lower aquifer water quality resulting from improper well installation. Beyond that the depth of the well will depend on desired water quality yield. A qualified water well driller working in your area should be able to help there. An environmental driller may be better at providing a suitable seal for the casing at the confining layer (assuming it exists and is continuous) below which you are currently pumping from.
Sounds like your local environmental regulation department might need to be involved.
Good luck
Believe none of what you hear......and only half of what you see.
Good Answers: 50
Re: Borehole Depth
01/17/2008 5:48 AM
The hole can be as deep as 4,000 miles. After that, you're just pushin' up dirt.
Register to Reply 15 comments
barhama (1); Blink (1); Camillion (2); MUKULMAHANT (2); nam70 (1); ozzb (1); Pepper (1); PWSlack (1); Sparkstation (1); The JMAN (2); vermin (2)
