Previous in Forum: High Temp Sump Pump   Next in Forum: Dark Energy......Or Slowing Time?
12 comments
Folding Tank
01/09/2008 12:36 PM
Various types of Liquids are transported by truck tankers.The transporter calculates charges considering empty return journey.
Let us develop a collapsible or a folding tank mounted on truck.The transporter will use the truck more effectively.
Ratnagiri
Good Answers: 40
Re: Folding Tank
01/09/2008 2:15 PM
Good idea, however, the cure is worse then the problem.
It is not very practical for the following reasons:
1. A collapsible or folding tank would be
  • far more expensive
  • far more likely to develop a leak (safety)
  • take both time and equipment resources to collapse and reform
  • more likely to have equipment problems
  • the extra resources would more then negate any small savings in fuel consumption.
2. The Safest and most practical engineered item is usually the simplest design with the least moving parts.
3. Trucking is inefficient unless it is used in both directions. It is necessary in short distances. For longer distances or large quantities it would be better to use trains, pipelines, or other form of transport.
Re: Folding Tank
01/09/2008 3:31 PM
Agree with most of your points, but for the first part of point 3), I think the OP was suggesting turning the tanker into a flatbed when the tank was collapsed (therefore able to carry other freight on the return trip).
United States - Member - New Member Engineering Fields - Biomedical Engineering - Biology, the most elegant Engineering Popular Science - Biology - New Member
Re: Folding Tank
01/09/2008 4:35 PM
I once worked with the owner of a small trucking firm that would haul milk to Florida from Massachusetts than haul orange juice back on the return trip. Since they were both food stuffs it worked, with only the time and expense to clean out the tank between each load. I believe most truckers try to haul both ways but the problem is getting scheduled for loads both ways. There are also some loads which laws won't let you put in the same tank, food and toxic chemicals for instance, no matter how well you "clean" the tank. So the real problem is scheduling all the trucks so no truck ever has goes empty on a long haul. Could a website be developed like an e-Bay site where a shipper could put up for bid a load to be transported and truckers could answer with offers to haul it? I throw that out there for the entrepreneurs.
Re: Folding Tank
01/10/2008 3:02 AM
Good idea. And, a really good database could reduce the total number of product/miles vastly. How often do you see trucks carrying identical cargoes in opposite directions on the same road.
Re: Folding Tank
01/10/2008 4:45 AM
<How often do you see trucks carrying identical cargoes in opposite directions on the same road.>
During the late 1990s, it was common for users of the M25, London's orbital motorway, to see a lorry loaded with concrete pipes going along the anticlockwise carriageway pass a lorry loaded with concrete pipes going in the opposite direction along the clockwise carriageway.
Silly, isn't it?
Good Answers: 15
Re: Folding Tank
01/10/2008 8:17 AM
Could a website be developed like an e-Bay site where a shipper could put up for bid a load to be transported...
Most good truck stops here in the US have a load board screen showing a variety of loads and the broker handling the load.
If you don't have time to do it right the first time, when are you going to have time to do it over?
Re: Folding Tank
01/10/2008 9:14 AM
I've heard of these boards at truck stops or at broker's offices but they are all very local and limited in scope. The whole process should be a lot more efficient if all these local "boards" were pulled together and made more easily available. All the work of course comes with trying to pull all the data together on a continuous basis. But e_Bay does something very similar so it should be possible.
Good Answers: 54
Re: Folding Tank
01/10/2008 5:32 AM
How about an inflatable or ballon-like tank? As you fill it, it expands and, as you drain it, it deflates. You'll need to work out the material to use but it sounds good to me.
If you disagree, be gentle...
Re: Folding Tank
01/10/2008 11:30 AM
How about shipping container with four or five balloons dividing the container volume.This may make task little easy.Container body giving stability by arresting the dancing balloons.
ratnagiri
Re: Folding Tank
01/10/2008 9:12 PM
Hello Chaps
I remember seeing these bladders years ago in Australia on the back of semi trailers carrying wine from fields to production lines.
This company has a pretty good looking range:
http://www.seatrans.co.za/
Mark Taylor, Senior Technical Advisor, CV Bli Tek, Bali, Indonesia.
Good Answers: 54
Re: Folding Tank
01/11/2008 2:36 AM
Jeez! Just when you think that you've come up with a new invention, you learn that someone's already done it .
Re: Folding Tank
01/10/2008 5:51 PM
I believe that you would find that since you must still move the truck the same distance, and the frontal area of the tractor unit remains the same, any fuel.savings would be negligable.
Register to Reply 12 comments
Anonymous Poster (1); charlie_r (1); Irving (2); JohnDG (1); PWSlack (1); Randall (1); ratnagiri (1); Tamu (1); techno (1); Vulcan (2)
