Previous in Forum: Would Wax Improve the Flow of Low-Melt Index Plastics?   Next in Forum: plasma coatings
Carbon
01/11/2008 4:30 AM
how the carbon remove from engine cylinder
Good Answers: 230
Re: carbon
01/11/2008 4:44 AM
Hello Guest,
You don't say what type of engine cylinder you have.
Try the Briggs & Stratton small Petrol Engine Instructions:
Have a look here: http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3439&p_created=1101709951
If you still need help, reply here with....
Kind Regards....
Re: carbon
01/11/2008 6:14 AM
Mechanical removal can be achieved by dismantling the engine and carefully scraping the carbon off the metallic parts, then reassembling it. This is sometimes known as 'De-coking'.
Some engine users advocate the 'Italian tune-up'. The procedure is as follows:
  • Locate a long rising gradient
  • Locate the vehicle at the foot of the gradient, stationary
  • Select second gear
  • Thrash the living daylights out of the engine and drop the clutch
  • Accelerate at full throttle until the engine is well into the red-line region for a few seconds
  • Reduce power and resume normal engine operation.
Good Answers: 230
Re: carbon
01/11/2008 7:20 PM
Hello PWSlack
My friend, Bartolomeo Gambino who lives in Cortona, Italy, had been having trouble with loss of power to his 2-stroke Lambretta-powered Carro di Gelato.
In a burst of inspiration, I advised him to try the 'Italian tune-up' remedy.
He had never heard of such named method of improving power, but being a young and keen sort of fellow, was prepared to give it a try.
There were complications in the translation, and poor Bartolomeo started at the top of the gradient, not the bottom.
His unfortunato Carro di Gelato gathered speed very quickly, scattering the ices far and wide, to the delight of the local children, as he accelerated downhill, the brakes of his cart being unequal to the combined effects of gravity plus full powered movement.
Unfortunately Bartolomeo was unable to slow down as a cement mixer truck crossed his path, and only a violent swerve by its driver, saved Bartolomeo from passing beneath, just before it toppled over.
Bartolomeo ended up in the local Hospital, as you can see from this photo he sent me.
Bartolomeo is now asking that intending users of the 'Italian tune-up' method of de-coking an engine to improve its power output, should carefully consider that unexpected results sometimes occur, from not carefully reading the complete instrucziones.
I have forwarded Bartolomeo a box of the finest chocolates available.
He is enjoying the fuss the are making over him, except for this one and is asking if a collection may be taken up, on his behalf, to enable his purchase of a new Carro di Gelato.
Kind Regards (il tipo considera)....
Re: Carbon
01/11/2008 10:10 AM
Any of several fuel treatments, or gasoline products with cleaning additives (Shell VPower is what I use..)
PWSlack (1); Sparkstation (2); Steve S. (1)
