Previous in Forum: Interconnecting Two PBXs   Next in Forum: mobile phone
Electic Solar Units
01/11/2008 7:18 AM
where do you find or which store sells 600volt/1600amps electric solar units?
Re: Stationary engineer, Refrigeration
01/11/2008 7:36 AM
Um, er, somewhere north of 19,000m2, um, er, now then, er....
Good Answers: 143
Re: Electic Solar Units
01/11/2008 8:22 AM
Guest,
Your request doesn't quite sound clear. Could you give a few more details? (And don't ask PW where to get an extension cord for that puppy).
Good Answers: 18
01/11/2008 9:04 AM
At that power level, I'd bet there is not a store with one on the shelf.
Try the international space station.
01/12/2008 7:15 PM
I have and tested a photovoltaic cell, 6x4 in that gives 0.5V at 2.5A. Test was in July at 12 noon.
To get the current that you've mentioned, you would need a battery of 640 such cells parallel connected. Call this Bat1, because that gives you the current that you want but only 0.5V (you understand that this is an academic discution; for the engineering details I will email you my bank account).
Now, to get the 600 V, you will need 1200 Bat1 devices.
All together, 768,000 primary cells.
If you are able to stretch them on a flat surface, the area would be 18.432 million square inch, or 128,000 square foot, or 2.938 acres. If you plan to install this monster in downtown Houston, at $10 mil/acre I sugest you to have a hefty bank account.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Bill (1); indel (1); PWSlack (1); TVP45 (1)
