Previous in Forum: Power House Earth-Mat Design   Next in Forum: DC Motor RPMs?
Power Supply for a Power House and Substation
01/14/2008 12:27 AM
which system is better 110V AC or 220V AC 1PH Supply.
prashanth N K
Re: control power supply for Power house and substation design
01/14/2008 12:55 AM
In terms of safety 110 v AC is better the lesser voltage , less current to flow onyour body
But in terms of econmy, 220 volts is good because you will need smaller wires in transmission
so the choice is still yours , which one do you prefer?
Big improvement starts with small changes
01/14/2008 3:55 AM
110VAC is used widely for control panel internal power supplies in the UK.
Re: Power Supply for a Power House and Substation
01/14/2008 8:40 AM
Normally 110 V ac is preferred from the safety point of view
01/14/2008 9:54 AM
As has been said 110 volts ac is preferred for outside work, but it is usually supplied by an isolation transformer with a centre tap to Earth.
So the maximum voltage to touch is 55 volts to earth.
John.
01/14/2008 12:13 PM
Hi, Prashanth
This depend on the primary source,but if heat loss is insignficant 110V AC 1HP is more preparable.
Anonymous Poster (1); autozam (1); Electroman (1); nesubra (1); PWSlack (1)
