Previous in Forum: Ventilating Steam Showers   Next in Forum: What are Thrust Load, Axial Load and Radial Load?
Methanol Handling and Storage
01/14/2008 2:20 AM
Good Day Mate I am gonna make storage for Methanol ( in 4 Silos with capacity of 75K Liter each ) Can anyone suggest what the best material for those silos and how handle the methanol coz they are so flammable . Say To fill them to storage and drain them.. Thanks Guys
Re: Methanol Storage and Its handling
01/14/2008 4:47 AM
http://www.coleparmer.com/techinfo/chemcomp.asp
It sounds as though there is an opportunity locally for a Chartered Chemical Engineer to assist with the design.
Re: Methanol Handling and Storage
01/14/2008 11:47 PM
The one I was looking at today (15,000 gal?) double walled, gap between walls, outer wall is reinforced concrete lined, a 8 inch blow off vent to prevent explosion from heat, plumbing is so if piping is damaged it does not continue to flow. Don't remember the brand.
It's a start
Brad
Good Answers: 120
01/14/2008 11:51 PM
methanol is a funny duck and you need to guard against corrosion.
http://www.google.com/search?hl=en&q=methanol+%2Bcorrosion&btnG=Google+Search
Per Ardua Ad Astra
01/15/2008 5:07 AM
Methanol is highly corrosive and will attack the welds and especially the heat affected zones. Carbon steel can be used but must be heat-treated. I would also use a force cured phenolic paint.
Double walled tanks and the tanks should be put in a spill control dike.
All associated piping must be heat treated also.
I would expect that to build tanks of this size, you will have to apply for local permits, and probably an EPA study will have be made.
There Will have to be some type of fire protection, again covered by local regulations and laws.
01/27/2008 1:07 AM
yakobus
pl reply my mail
01/30/2008 4:19 AM
Sorry ..took so long to reply...
someone shouted behind me..to use HDPE .., what do you think?
02/10/2008 8:14 AM
No Plastics at all!
"Methanol is especially damaging to rubber and
plastic parts. Parts that come in contact with the fuel need
to be damage resistant. These include the fuel tank, fuel
lines, fuel injectors, fuel pumps, and filters."
Your best bet:1mm thick Aluminium inner skin fitted into a loose fitting steel outer of full strength.Radial gap between Al&Steel=25mm. fill up with lightweight concrete which will set hard permanently.Piping out from Aluminium inner tank has to be tested thick strong Al to flange out of Steel outer. Beyond--SS304.
Register to Reply 7 comments
aurizon (1); jmart23 (1); MUKULMAHANT (2); PWSlack (1); U V (1); yakobus Priyagung IN (1)
