Previous in Forum: Total harmonic distortion   Next in Forum: Power Supplies
specfic speed
01/16/2008 4:50 AM
sir,
1. what is the specfic speed of the water turbine? what is the formula to calculate the specfic speed of the turbine.
2. What will be the specfic speed of Frances Turbine, Pelton Wheel, Kaplan Turbine,
3. Specfic speed will be less than <1 or greater than >1
please help me in detail.
yogendranath
Re: specific speed
01/16/2008 12:48 PM
1. what is the specific speed of the water turbine? what is the formula to calculate the specific speed of the turbine.
Depends on the the turbine, the water source used to power it and what it is driving.
2. What will be the specific speed of Frances Turbine, Pelton Wheel, Kaplan Turbine,
See answer to question 1.
3. Specific speed will be less than <1 or greater than >1
Greater or less than 1 what?
dear guest,
In order to give meaningful answers to your question, we need some actual details of the installation you propose, (size, shape, type, what it is to be used for, water source, flow rate, head etc).
Without specifics, you may as well as the question
'How long is a piece of string?'
With relevant details we may be able to help.
Vote for something useful this time, vote to repeal the second law of thermodynamics!
Re: specfic speed
01/17/2008 12:36 AM
1.Specific Speed is a term related to speed of a Hydraulic Turbine Type.
It is equal to the Speed of aturbine of a given type,but of a size that of a head H=1Metre
For Example :
Let us find the Specific Speed of a Turbine whose Speed is n,Head H metre ,Power=unknown--
Then ns/n= ( D÷Ds).(1/H)0.5 ---where Ds--is the diameter of a turbine with Power rating=1h.p.
after juggling with units we get ns=n/H(Nhp/√H)0.5 . Here Nhp is N shown in HP (N kwx1.36)
2 Sp. Speeds are__
Francis(Radial/Axial)------ 400>80
Pelton Wheel (Impulse) -- 50>10
Kaplan(Adjustible-Bladeaxial Flow) 1200>450
Re: specfic speed
01/17/2008 12:29 PM
Hi Mukulmahant,
Fascinating, I learnt something new today!
