Previous in Forum: electronics math formula   Next in Forum: Motor
Distribution Line Tie In
01/17/2008 9:21 PM
Please any advice...our distribution line feeder A is 24.94kv/14.40kv WYE/3 phase/60hz. We are planning to Tie In to other Feeder D with a different incoming Voltage & source 23.90kv/13.8kv WYE/60hz. The voltage difference will be Pri 1040 volts / secondary 600 volts. What will be the best way tie them together to met the same voltage.
Note: The Feeder D source will be standby to supply back in case Feeder A get a problem. Any suggestion or idea what we need or device to be use. Thank You
Re: Distribution Line Tie In
01/18/2008 2:45 AM
Hola,
I think you should use a Y-Y transformer rated 23,90 kV – 24,94 kV connected in the feeder "D". You have to check that feeder "D" phase shift is the same as feeder "A".
Chao
BAM
01/19/2008 6:50 AM
There are many ways to do this. Can you let us know what is the final voltage ie 13.8 kv/?.Are u also planning to use when one feeder is off or both simultaneously?
01/19/2008 3:14 PM
My first thought is
WHY?
MR GUY
If you are looking for a positive answer..it's YUP......
Good Answers: 93
01/20/2008 6:27 PM
I don't fully understand what you are doing, or what you are doing it with. However I did study and find that in a voltage regulation transfer between Mexican and US Grid systems one company had converted all the power to DC, which had enabled conforming to AC within a phase range that did not overpower the neutral.
Check with Switchman.
You don't get wise because you got old, you get old because you were wise.
01/20/2008 8:09 PM
Firstly you need to tell us what your final voltage required is. Assuming that this is 14.40kV the simplest way is to get a 23.90kV/14.40kV transformer and a change over switch. Ensure the phase rotation is the same way. Parallel the new transformer with the existing 23.90 one and connect the change over switch on the secondary side of both transformers
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
01/21/2008 9:45 AM
You do not provide enough information. Are the feeders overhead or underground? Do they come from the Utility or a company substation? I would suggest hiring a good electrical consulting engineering company. This is a voltage level that requires competent design work.
Register to Reply 6 comments
Anonymous Poster (1); bam (1); coconutpete (1); Mr. Guy (1); nesubra (1); Transcendian (1)
