Previous in Forum: seminar   Next in Forum: Wattmetric protection in main High Voltage supply
Answer to formula (1-r1/r2) Explained
01/19/2008 3:06 AM
OHM's Law can be used for calculating the current through the LED for a range of resistance values.R1=100 Ohms.LED current=.043vThe formula for current is I=V/R.An LED doesn't begin to conduct untill forward voltage is 1.7 volts(red LED).Therefore the formula for current is I=(6v-1.7v)/R or risistance.Which Can be found In Radio Shacks book,"Electronic Formulas, Symbols and Circuits".Thank You,
By D.w.Howerton
Scientist/Electrician/Electronics Teck.
Re: Answer to formula (1-r1/r2) Explained
01/19/2008 9:06 AM
Hmmmm a simplified version, but who are you answering? Or are you expecting a debate?
John.
Good Answers: 54
01/20/2008 4:44 AM
I think his title is referring to this thread:
http://cr4.globalspec.com/thread/16556#newcomments
However, the rest of his post seems to answering some other thread or post. Even though, it doesn't make sense. Too bad there's no bad answer score .
01/20/2008 7:57 AM
any how thanks for the information though i am not able to relate to a particular post/thread
01/20/2008 12:18 PM
Is that D.W. Howerton, the renowned facial reconstructive surgeon?
Good Answers: 230
01/20/2008 3:49 PM
No, JohnDG
Refer: <"By D.w.Howerton
Scientist/Electrician/Electronics Teck.">
I'm unsure why the second name has a small 'w', it may be something like the 'd' in French, or the 'van' in Dutch.
Teck is a word with multiple meanings, from a Chinese surname, City in Germany etc.
Google Search terms: teck meaning (Unbolded, of course) should give you varied examples, if you wanted to know more.
Kind Regards....
Electroman (1); JohnDG (1); nesubra (1); Sparkstation (1); Vulcan (1)
