Previous in Forum: Bark (what a question from a Cat!)   Next in Forum: solar cell ?
Lap Timer
01/26/2008 12:06 PM
I would like to build a lap timer system for my slot car track. I need to come up with the triggering device that will be used register when a car has passed, which will start the timer as well as record lap times. I would rather not use a 2 peice setup, such as emitter and detector LEDs. Possibly magnetic reed switches or maybe some sort of distance measuring device. I also need a way to interface this with a pc and might need to write some sort of software for capturing and displaying the data. Any suggestions?
Good Answers: 97
Re: Lap Timer
01/26/2008 12:44 PM
Try the LED and sensor from a balled mouse.
An optical mouse (upside down) might just measure velocity as well.
A coil with a magnet passing over it.
A limit switch.
Old turntables had a nice sensor.
Re: Lap Timer
01/26/2008 1:31 PM
check veeder root
Re: Lap Timer
01/28/2008 5:14 AM
These people make a lovely little device called the IRDOT [Infra-Red Detection Of Trains]. Though intended for the UK model railways hobby it must surely have application here? Simply connect the relay output clean contacts to some sort of timer/counter.
Usual disclaimer applies.
http://www.heathcote-electronics.co.uk/
Register to Reply 3 comments
Hendrik (1); KENN (1); PWSlack (1)
