Previous in Forum: Plain bearings vs rotation speed = oil wedge   Next in Forum: Wiring Diagrams for USB Cables?
9 comments
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Terminology: Fibre Optics vs. Optical Fibre
01/31/2008 8:45 PM
Do the terms 'Fibre optics' and 'Optical fibre' convey same meaning or are these separate technologies / applications?
nvmani
Good Answers: 230
Re: Fibre optics
01/31/2008 10:06 PM
Hello nvmani
The Umbrella or General Term:
"Fibre Optics" is everything to do with light transmission, modulation, control through a fibre, generally made of special glass, but could be made of almost anything in Fibre form: Ice, Translucent Plastic, and other materials which could fulfil any or all of those above functions.
The Specialised under the above Umbrella Term, Term:
"Optical Fibre" is a general term applied to the special glass fibres, used to transmit, modulate or control light, from one place to another.
These fibres are used mostly for Control and/or Communication, in cables, mostly on land or undersea, and Internet, TV, Radio, and other Communication links today travel in some degree via "Optical Fibres".
Hope that assists you.
Kind Regards....
Re: Fibre optics
02/01/2008 6:49 AM
Good answer,to the point with clarity. Thank you.
nvmani
Re: Fibre optics
02/02/2008 9:43 AM
Good answer, the only thing that I would add is that generally it is the same or similar types of fiber used for both.
But particularly for data transmission at very high frequencies and longer distances, there are some very fine glass fibers that are so fine that light does not get reflected back and forth from the sides (multi mode) but ONLY goes down the fiber center in what we call single mode.....these types would normally not be used when you need to illuminate something visually from a distance I feel, but I could be wrong there. Anything is possible!!
Nigeria - Member -  Member
Re: Fibre optics
02/02/2008 10:00 AM
Good answer but let me add, with reference to cable;
Fibre optic cable refers to the entire cable constituents (core, cladding, sheat and armour and the bundle in a multicore cable)
While optical fibre cable refers to the fibre core (i.e. the single strand)
Cheers,
Ethobil
Join us to make the world a better place: Propergate peace.
Re: Fibre optics
02/03/2008 6:29 AM
Good answer and good comment
Re: Terminology: Fibre Optics vs. Optical Fibre
02/02/2008 10:29 PM
Fiber optics is a field of engineering and technology including all components of an optical transmission of data, from the transmitting laser to the receiver. In between, there are optical fibers or cables, optical connectors, splitters, repeaters, drop-ins, etc.
Optical fiber is just an efficient pipe for light. Besides telecommunications, optical fibers can be used for photonic transmission of power or direct transmission of an optical image such as endoscopy.
Good Answers: 94
02/04/2008 6:15 AM
Agreeing with Hottech, we use blocks of Fibre Optic material to transmit images over a short distance. These are hard, solid blocks made from bundles of glass optical fibres & the ones we use are anything from 18mm to 200mm in diameter.
02/17/2008 5:14 PM
Hi Nigh,
Please tell me where are made those optical clads you say you use. I'm interested to find a supplier for a custom made one.
Thanks
Good Answers: 94
02/18/2008 5:00 AM
In the US Schott & Incom, in Europe Phillips, in China Centech.
Register to Reply 9 comments
Andy Germany (1); Anonymous Poster (1); ethobil (1); Hottech (1); melshamy (1); Nigh (2); nvmani (1); Sparkstation (1)
