Previous in Forum: Bearing Life Equation   Next in Forum: Rocketing Wheelchair
Guide to Mysterious Engineering Symbols
02/01/2008 8:06 AM
As I read documentation of a technical nature I often come across references and symbols with which I am not familiar. For example, in reference to shaft tolerances the symbols "dn<50000" and "C/P>10". Am looking for an engineering reference (glossary of terms) that would help in understanding a broad spectrum of terms. Would appreciate pointing me to some references. Thank you.
Re: Guide to Mysterious Engineering Symbols
02/02/2008 7:17 AM
I can't help you here, but I must see the answers of our peers. I have been having enough trouble lately just translating from other languages to English
02/02/2008 11:53 AM
Are these shaft tolerances related to bearing fits, at this point in time I have some hazy idea that this maybe the case and related to shaft speeds also.
02/04/2008 9:24 AM
It is indeed. Your hazy idea is precisely the case - sorry I wasn't more specific. If you have some reference to a glossary of symbols that would be excellent.
02/04/2008 9:36 AM
Can't promise anything, but will see what I can come up with over the next few days.
02/04/2008 11:29 AM
Another hazy idea.
The "C/P>10" looks like some kind of hybrid surface texture parameter symbol dealing with bearing ratios.
I'm also interested in what others say.
Sucess is going from failure to failure without loss of enthusiasm... Winston Churchill
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
02/11/2008 2:23 PM
I got this answer from my tool and die guy I hope this helps! If it is a spindle shaft the DN is a surface speed rating. This is calculated by multipling the od (bearing journal) in millimeters by the service speed (rpm) i.e. 40mm x 1000rpm = 40000dn . This shaft is less than 50000dn. It is simply a easy version of surface speed without PI. Widely used in bearing speeds.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
02/11/2008 4:18 PM
Most helpful and precisely what I needed. Thanks!
logix101 (1); MOBI (2); my2001 (2); Q (1); qaqcpipeman (1)
