Previous in Forum: turning moment   Next in Forum: eNOSE or IMS or both - Technology Challenge for Future
speed increment
02/02/2008 1:13 AM
i m having a car as a model to demonstrate for the event ...
what r the various ways to increase the speed of the car ?...suggest me the technology which can bear heavy thrust and can easily pass the road having a lot of barriers.
This discussion was "closed" on 02/04/2008 8:00 AM. No new comments are allowed.
Message from admins:
Questionable intent.
Re: speed increment
02/02/2008 10:25 AM
A rocket booster will do the trick:
http://www.greatscourge.co.uk/bc_cycles.htm
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 120
Re: speed increment
02/03/2008 12:24 AM
http://www.youtube.com/watch?v=CGvMVn38Eu8
A few brave men at a secret desert site on Nevaduine make a thing go fast
http://www.youtube.com/watch?v=C2GZ4Uxoa9s&feature=related
But the Emperor is alert
Per Ardua Ad Astra
Good Answers: 243
Re: speed increment
02/03/2008 1:28 AM
"suggest me the technology which can bear heavy thrust and can easily pass the road having a lot of barriers."
As long as my daughter is in Uniform, I think I'll keep my ideas to myself!
I'm just not sure what your idea of payload for the car or event is.
milo
Re: speed increment
02/03/2008 2:17 AM
Improve the aerodynamics. Remove weight. Fit a more powerful, lighter, smaller engine. If the barriers involve high speed cornering then ground effects are a very potent addition. If the course is on tarmac you need to consider tyre compounds. If the course doesn't involve high speed cornering then look to narrow your tire profile and the tire drag as much as possible. Use a hard compound and slim profile on the tyre if the course is just a straight line. If the course has corners then you should look to using slicks with a wide profile and a suitable compound that's approriate for the course. If you study everything that F1 looks at and utilises you won't go far wrong, but all additional speed costs additional money at an infinitely escalating ratio.
Good Answers: 15
Re: speed increment
02/03/2008 6:06 PM
Have you checked out http://auto.xprize.org
What type of throttle are you using? cable or wired? wired uses a pot on the accel pedal and a servo on the throttle body, you can possibly get a RC servo to do the same job on the cable driven throttle.
how much thrust or pulling force do you require?
a Suzuki mightyboy, those little cars that the tray on the back couldn't fit a hay bale, that had a 660cc engine, or a BIG DAF 12L Diesel turbo truck? I think those are wired throttles.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Re: speed increment
02/04/2008 6:55 AM
The (in)famous motoring journalists on BBC Televison's "Top Gear" programme once tried to get a Reliant Robin into orbit as part of the UK's next step in its space programme. Jeremy Clarkson, James May and Richard Hammond are just waiting for the call......
http://www.topgear.com/
Canada - Member - BC Born, Alberta Raised, Quebec (poutine) crazed... Engineering Fields - Aerospace Engineering - An airplane is just a bunch of beams... Hobbies - Model Rocketry - Had fun as a kid...fun stuff Hobbies - CNC - dreaming of cutting Engineering Fields - Control Engineering - PID ME!
Re: speed increment
02/04/2008 7:23 AM
Where's the science people?!?!?!
If F=m*a then to get a to increase then you can either:
  1. Increase the force applied (rockets seems to the be favorite)
  2. Decrease the mass... Get rid of that SUV and make and armored SMART car with the same engine power! A smaller car could drive AROUND and BETWEEN the barriers on the road...and squeeze into a smaller parking spot in front of the movie store.
kkjensen
Register to Reply 7 comments
Anonymous Poster (1); aurizon (1); indel (1); kkjensen (1); Milo (1); PWSlack (1); Snaketails (1)
