Previous in Forum: How To Understand Enclosure Format 2U 3U etc   Next in Forum: Installation of Submarine Cable
Designing a Venturi
02/05/2008 6:16 AM
I am looking for a way to design and fabricate a venturi unit to use for presurizing a liquid dispensing syetem. I have in the past fabricated Positive Pressure air vacuums, which have a small spool inside an outer pressurized casing.. I would like to have the air do all the work to blow thru and atomize if you will, the liquid that is being pulled through a tube from a larger container. The air pressure would be exiting several sets of precision air blasts, at which point I would like the liquid to exit as well. I have looked for drawings online and have only found the Wikipedia drawing explaining Burnelli's Law. The fabrication is no problem at all, I would just like to find a nice set of prints, it makes it a little easier than just hogging one out of a peice of round stock..Thx alot and thx for letting me in the site,, I hope to use this site for alot of questions and theories I have..Dean
Re: Designing a Venturi
02/05/2008 7:05 AM
This is a link to a nice interactive demonstration that you should be able to use as the basis of a design.
02/05/2008 7:47 AM
<....I am looking for a way to design and fabricate a venturi unit to use for presurizing a liquid dispensing syetem. I have in the past fabricated Positive Pressure air vacuums, which have a small spool inside an outer pressurized casing.. I would like to have the air do all the work to blow thru and atomize if you will, the liquid that is being pulled through a tube from a larger container.....>
Sort-of-like an airbrush, for example?
02/05/2008 10:17 PM
Yes sorta like that. I will be spraying a concentrated cleaner on a rotating brush. I don't want the cleaner to just drip or run out, thus not covering the surface of the unit. I have installed atomizing air nozzles so the cleaner will come out in a spray form..
02/05/2008 9:00 AM
Or a perfume spray pump action??
Good Answers: 66
02/05/2008 12:20 PM
Or something like this guy...? Not sure what kind of throughput you're after, but perhaps you could scale it up...
Aequam memento rebus in arduis servare mentem.
02/05/2008 3:31 PM
There have been quite a few venturi threads recently... search the site for venturi.
Location: Somewhere in the hills of Pennsylvania, I think.
02/06/2008 2:11 PM
If it were my money being spent, I would use the available air to operate a diaphram pump and pump the liquid cleaner to a "Tee-Jet" spray nozzle.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Register to Reply 7 comments
Anonymous Poster (1); CSM Engineer (1); Electroman (1); FKIA (1); JohnDG (1); PWSlack (1); user-deleted-1105 (1)
