Previous in Forum: Shock Absorber Test Method?   Next in Forum: Beckman Function Generator, Model FG 2A?
non contact data collection method
02/05/2008 7:07 PM
can any body suggest what kind of instrument i can use for collecting the data with out contact(remote sensing) from a distance?
Design executive
Good Answers: 230
Re: non contact data collection method
02/05/2008 11:18 PM
Hello asishonline2000
A) Please advise what data you hope to collect:
  1. Vibration
  2. Rotation
  3. RPM
  4. Movement
  5. Temperature
  6. Pressure
  7. Humidity
  8. PH (Acidity/alkalinity ratio)
  9. Optical transparency
  10. Water Chlorine level
  11. Wind Speed
  12. Cloud Cover ratio
  13. Rainfall
  14. Dewpoint
  15. Snow thickness
  16. Daylight hours
  17. Fireball size of mushroom cloud from nuclear explosion
  18. The list goes on, and on, and on - Please specify what data you intend to collect remotely....
B) Please also advise over what distance (how remote) your sensors need to be.
C) Advise any further information, as required.
If you reply, with, it may be possible to assist you.
Kind Regards....
02/06/2008 9:26 AM
The data from whatever you are measuring can be sent using a wireless link such as Bluetooth etc...
That's assuming the data doesn't need to be secure or is of a safety issue and is within range of about 50 metres.
John.
Good Answers: 59
02/07/2008 11:41 AM
As Spark said before, we advise on specific questions. If you need recommended teaching material, that is a possible, and likely available.
02/07/2008 2:21 PM
Leveles, read some of the topics on CR4 you will find a large number are fairly non-specific questions...
When you say 'we' please refrain from including the majority of posters in your category!!
John.
Good Answers: 230
02/07/2008 6:33 PM
Hello Electroman
Perhaps Leveles intended the "we" in the manner of "The Royal 'We' ".
Just a thought.
Meanwhile we await the reply from asishonline2000 with some clarifications and
Kind Regards....
Electroman (2); leveles (1); Sparkstation (2)
