Hi Guys
I have a general flatness tolerance on a drawing of 0.0015".
My supplier did the measurements on 50 parts using a smartscope. I have one measured flatness value per part. i.e. 50 results.
- Some values are negative – indicating concave
- Some are positive – indicating convex
The part is a small metal laminate made of copper plates brazed together). Looking at the results – they have a high standard deviation.
Frankly – I'm confused – I'm not that familiar with flatness.
I want to calculate the Cp & Cpk to get idea of whether their process is in control or not.
I have two problems
- Is SPC valid on for flatness – I have been told not. What is your opinion
- Interpretation of flatness spec:-
In my ISO spec, it states that "indicated surface is required between two imaginary parallel planes X apart" (X in my case being 0.0015"). So is it
a)
- Nominal: 0
- USL: +0.0015
- LSL: n/a
b)
- Nominal: 0
- USL: +0.00075
- LSL: -0.00075
c)
- Nominal: 0
- USL: +0.0015
- LSL: -0.00015
Yours in confusion
J.
