Previous in Forum: Double Earthing   Next in Forum: Electrical power cable cabinet penetrations.
10 comments
Do It Yourself PICkit2 programmer design, Au Group Electronics-CB0703
02/06/2008 11:05 AM
This is a Do It yourself design on PICkit 2 programmer: Au Group Electronics-CB0703.
Major feature:
  • small size with SMD design: 72mmx32mm, slightly smaller than Microchip design though more function is included.
  • RJ12 ICSP interface make it possible to be easily adapted to work with board designed for ICD2.
  • external power supply circuit is included.
  • support both USB type B and MiniB connector
  • fully compatible with Microchip design down to the components name level.
Here are two photos showing two fully assembled boards:
1.Board assembled with USB type B connector.
2.Board assembled with USB-miniB connector, highlighted part is the external power supply connector.
Schematic, PCB drawing and step by step assembly guide will be uploaded once I figured how to make an attachment of PDF files.
Good Answers: 52
Re: Do It Yourself PICkit2 programmer design, Au Group Electronics-CB0703
02/06/2008 11:25 AM
Would you be interested in moving this into the Workbench Creations blog? I built a much more basic pic programmer in the past, so I think this project would be a good fit. Just contact Moose or me and let us know.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
02/06/2008 12:34 PM
That's a lot of work to go through for a $50.00 item. That is, unless you are doing it for fun. If I wasn't doing some other things and I didn't already have one, I might do it.
Thanks!
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
02/07/2008 8:16 PM
Mikey, I'm new to this forum and so I haven't seen your posts before now. I just have to say I really enjoyed that George Elliot quote. I usualy try to say(when I'm not too full of myself) "The older I get the less I admit", when I am tempted to rattle on about some subject.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
02/08/2008 8:04 AM
Hi Shadetree,
Welcome to CR4! I find that I spend (probably) more time than I should here. I'm learning a lot of new things though.
Now, with a quote like that, I'd better watch myself to keep from going on and on...
Not too much chance of that though as I type V E R Y S L O W L Y
Again, welcome!
Mike
03/21/2008 8:02 PM
The CB0703 PCB is now on sale for US Dollar 1 cent for PIC fans and students.
Due to the high demand of CB0703, this special price is limited to 1 piece per order.
04/15/2008 11:59 PM
Now a Rev C version of step by step assembly guide has been released on the web:
http://www.auelectronics.com/Hardware-CB0703.htm
http://www.auelectronics.com/pdfs/Assemble_PICkit2.pdf
A BB0703 (PICkit 2) "Programmer-To-GO" You Tube video is also added:
http://www.auelectronics.com/System-PICkit2.htm
11/18/2008 9:19 PM
Our new "BB0703+128K" and "BB0703+256K" are now available for immediate shipment.
This is the second generation design based on our popular "BB0703" (PICKit 2 based) products.
The "BB0703+128K" and "BB0703+256K" come with all enhanced feature of "BB0703", plus the following new enhanced features:
1. Buck/Boost voltage regulation circuits are now standard on all "BB0703+" family. This feature guarantees the ICSP programming working correctly even when USB power supply dropped down to 3V.
2. Native support of 256K EEPROM on "BB0703+256K", no hardware modification is necessary to take the advantage of 256K memory for programmer-to-go (PTG) feature.
Other major features:
*Full implement of Microchip-recommended PICkit 2 circuits
*plus unique enhanced features such as: external power supply, RJ12 interface, buck/boost voltage regulator etc.
*Well designed hardware, no "Vpp pumping" is required
*Dimension:3" L x 1.72"W x 0.81"H (77 x 43.5 x 20.5 mm)
*Color: PC white or Black
*USB power supply: 5V 100 mA
*USB connector: Type B or Mini-B
*Enhanced extra power supply (Optional): 9V 100 mA, positive center
*ICSP interface: RJ12 6-Pin
*Chip support: baseline (PIC10F, PIC12F5xx, PIC16F5xx), midrange (PIC12F6xx, PIC16F), PIC18F, PIC24, dsPIC30, dsPIC33, PIC32, and Microchip Serial EEPROM products
*A RJ12 6 pin reverse cable included, BB0703+ can work directly with board developed for ICD2/ICD3/RealICE for programming and/or debugging
Details are available at:
User Manual is available at:
http://www.auelectronics.com/UserManual-BB0703.htm
Funny N.
Au Group Electronics, [url]http://www.AuElectronics.com[/url]
Funny N.
01/26/2009 11:38 AM
Thanks for all you guys inputs, there is some special sales event for all people provides helps.
Please see the bottom of this web page to redeem the little thanks we can offer:
(The quantity is limited and it is a first come first service.)
Some Sample of photos of the special sale:
major feature lists of BB0703+, BB0703, and closest competitors:
05/14/2009 8:41 PM
Here is a tutorial on understanding the PICkit 2 hardware:
http://augroups.blogspot.com/2009/05/understanding-microchip-pickit-2-rev.html
It covers some basic design concept on PICkit 2, such as USB voltage, Vpp Boost, Vdd detection and generation, PGD, PGC and Aux voltage clamping, etc.
Funny N.
09/30/2010 10:17 AM
Now the 50 mil pogo pin cables are released:
6 pin pogo-pin cable (0.100 inch pitch)
50 mil (1.27mm) pogo cables:
CBL-0703-POGO-50R: 6-wire 50 mil Pogo Pin (radius header) Cable for Au BB0703
The following is the info of the same 50 mil pitch pogo cable but with a serrated header:
CBL-0703-POGO-50S: 6-wire 50 mil Pogo Pin (Serrated header) Cable for Au BB0703
The following is the PCB pads design for either radius header or serrated header:
For Radius header:
For Serrated Header:
Anonymous Poster (4); frankd20 (1); FunnyNYPD (2); mikey (2); Shadetree (1)
You might be interested in: USB Connectors, USB Products, Connector Plates
