I was surprised to see separate electrical cable cabinet penetrations for each phase at an oil platform in the Golf of Mexico. I have always considered that all the three phases of a power cable (including the neutral/ground if applicable) must use the same penetration. This is to minimize the induction of current in the cabinet steel. Although parallel groups could use separate penetrations. The practice of having one phase per hole on a steel cabinet (at many hundreds of amps) seems to be common there as I saw many examples of it. Is it an acceptable practice or is it just a cheap job?
